davidschaffer
Location
Benzonia, Michigan
Biography
99 Outback with a 2.2
Vehicles
99 Outback
davidschaffer's Achievements
Advanced Member (3/11)
0
If I had a garage I might take it on. In my sandy driveway I am going to steer clear of any transmission work. I Hope to have a pole building up this fall. Do you think the car is worth $800? That is if it checks out being nearly rust free and well maintained. If I spend a grand on the clutch and other minor fixes I would be in for $1800 for a 95 with 218000miles. That seems high but if it really is rust free, that is a luxury here in Michigan. Plus I have a lower Mile engine ready to go when need be. Thoughts?
If I had a garage I might take it on. In my sandy driveway I am going to steer clear of any transmission work. Hope long to have a pole building up this fall. Do you think the car is worth $800? That is if it checks out being nearly rust free and well maintained. If I spend a grand on the clutch and other minor fixes I would be in for $1800 for a 95 with 218000miles. That seems high but if it really is rust free, that is a luxury here in Michigan. Plus I have a lower Mile engine ready to go when need be. Thoughts?
I'm going to look at the wagon on Saturday. The details so far are that it runs good but the manual transmission no longer goes into gear. It was sudden. It will go into each slot but no shifting takes places, just stays in neutral. Would this be the clutch? It has 218,000 miles and supposedly no rust. The seller is askimg $800. Was owned by a church to run kids around on the summers only. Timing belt supposedly changed at 200,000. It would cost me about $1000 to have the clutch done at a local shop or they would swap motors for $900 plus parts. Any thoughts?
I have a 99 outback with a EJ22. From what I was told, the engine came from a 98 Impreza. The car is falling apart but the engine, with around 100,000, seems to be running quite well. A local shop will do a typical engine swap for $600. I would like to buy the nicest Outback I can find with a blown motor and have them put the 22 into it. What years am I limited to? Thanks
Sorry for the delayed report. I can't seem to get notifications from this thread. The leak was the lines going through the body above the gas tank. I had a local Subaru guy flare in new lines up to the rubber hoses. He could not get the air out of the lines as the front passenger bleeder broke off. Apparently I need new hubs, calipers and pads all around. I'm pretty the back breaks aren't working at all. He wanted close to a grand for the work but I'm going to do it myself for around $500 in parts. Thanks for the help. I trued to post pics to help the next guy but it says the file is to big.
Thanks for the replies! I would have responded sooner but did not get any notice that people had replied. 99 outback. The front rotors are pretty worn. I have not had time to do anything but pump the breaks and look for leaks. Hopefully I'll get some time soon to pull the wheels and see if it is as some of you suggested. I'll let you know what I find. Thanks again
Hey all. The other day the break light came on but because there was no signs of any issues I ignored it. That was a mistake. On my way to work yesterday the breaks started to feel soft. When I pulled into my spot at work I have no breaks at all and rolled into the snowbank. Looked under the hood and no fluid in the resivour. I later filled it up and cautiously drove home. The breaks are spongy and I need to pump a bit for them to work solid. I can not find a leak anywhere and the fluid level has remained the same. What's going on?
My 99 outback with a 2.2 from a 98 Impreza probably needs a new trans. It does the delayed shift into drive. When I use trans x, it works for about a month then back to delayed shift. Can the tranny be rebuilt or is it more cost effective to swap in a new one? Also, what trans can I put in? I don't want another one with delayed shifting problems. Thanks
- 13 replies
- Outback
- Transmission
(and 5 more)
Tagged with:
