kvaleras
Everything posted by kvaleras
Hello all, I have two questions: 1) Can anyone give me an estimate on replacing both rack-and-pinion boots? I called around and was given anywhere from $100 to $200 per side. The car is Subaru Legacy L 95 FWD. 2) Does anyone know a reliable mechanic in DC area? I am willing to travel if it takes that. Thanks a lot!
Hello! Some time ago I noticed the noise coming from the front of car while braking at 55+ mph. It wasn't bad, plus it turned out brake rotors were badly worn. So I replaced them, and there wasn't any noise. Well, not for long. A little after rotor replacement, the noise came back on, only louder, and at 40+ mph, and sounded like metal clanking, sort of a blacksmith sound. Last week I replaced brake pads, but nothing changed, only I noticed the noise becomes louder and especially when I brake while turning right. What should I look at? Can I somehow inspect weel bearing? Thanks a bunch!
Hi, all, A couple of days ago I replaced the coolant temperature sensor on my Legacy. Today ``check engine'' light came on. Went to the Autozone, pulled the code: P0101 Mass or Volume Air Flow Circuit Range/Performance Problem What could it be? I suspect it is related to the latest repair - I removed the big hose connecting the air flow sensor with the throttle body. Am I right? Thanks!
Dear all, I wanted to replace the coolant temperature sensor on my Legacy L 95, and searched the forum on that subject. Found plenty of helpful information, however it is not really clear if one needs to drain some of the coolant. Some say yes, while others don'y mention anything about that. So, if the cooland needs to be drained, how do I do it? There are several members of the forum that do not recommend draining through engine block drain plugs. If not through those, then through thermostat? Or something else? Thanks a bunch! Val.
Hi, all! I recently purchased a basic scantool for OBD II from Harbor Freight (CEL was on for some time). When I tried to read the codes, here's what I got: 1) It displays ''LAUNCH'' (as it says in the manual). 2) Then it shows three dashes, then pauses, then shows the fourth dash and then it gives ''E''. I know there a trouble codes in my ECU (I flushed them couple of times - thanks to all your advice, users). Anyone who uses or used the mentioned scantool, I need your help! Does ''E'' mean empty, no codes? I do everything that is said on the manual, but maybe I'm missing something? Is there a chan ce the scantool is not suitable for my car? Thanks!
