D3F0
D3F0 last won the day on January 29 2016
D3F0 had the most liked content!
About D3F0
- Birthday 09/23/1993
Gender
Male
Location
United States
Interests
Building Cars and Motorcycles
Occupation
Student
Biography
I am going to college in Boston for Mechanical Engineering.
Vehicles
1988 Subaru RX and 1987 Chrysler Conquest TSI
D3F0's Achievements
Advanced Member (3/11)
15
I am doing this exact same swap, there is not a lot of information on it. Also i am swapping the dash over I have all the parts including ecus and dashes. Cant wait to dig in once I have some free time.
So, I guess I'm building a Rallycross car! 1995 LX coupe...
D3F0 replied to obk25xt's topic in Members Rides
Thats just lovely, sounds and looks like a great time! -
How much Boost are pushing through that baby snail. I love those ej22Es so dam reliable. Good fix with the head bolt/stud issue, it really does suck when Subarus fight back. -
Yea i just have to take a look I bet it all bolts up and I just have to keep all the shims on to keep the back lash the exact same as before.
Alright fine Ill use my legacy 4.11 5 speed instead lol thanks for the advice.Do you guys usually just swap the ring gear at the back to 4.11 to mach the tranny. Is that possible with that awesome rear LSD? Or do i have to do a bunch of crap and locate another diff. Currently I have an SVX/legacy hybrid built 4.11 and i doubt the RX axles would slide right into the SVX LSD prob different splines and length. ALSO LOVE THAT VIDEO I love it all haha
Subaru Down!; ea82t 88 gl-10
D3F0 replied to Brokenneckj's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for the response =) also good luck finding a another controller. -
If i were you I would take the back of your extra RX trans and put that on the back of an EJ trans with either a 3.7 or 3.9 final drive to match your diff I recommend that so you have the locking center of the RX tranny still and use the newer Ej trans to bolt the EJ22 you already have. With this option there is no need to to buy an adapter plate. Then turbo everything and I am sure with that option it will all hold together for some launches assuming you are not doing it at redline. EA82 are not that much fun to mod you would have way more fun building a turbo 2.2 using the old legacy heads if you can find them or lower compression and boost that baby.
Hard launching and Subaru shouldnt be said in the same sentence. Everything always breaks that way. Oh well thats too bad good luck with your future plans.
With the EJ18 ECU My redline was 500 rpm lower than the stock EJ25D had stock. Is your car actually revving out to redline?
I wonder how long it would take your average person to do a headgasket in an EA82. It took me and my buddy 7 hours to do a headgasket in a 2007 impreza. I have never looked at the service manual. Do you have to remove cams to get to head bolts like the DOHC EJ motors or can you leave the heads together and just unscrew the 12 or w.e headbolts to get it apart? -
What do you mean you broke it and the trans? You blew the engine and stripped the transmission?
When you say as the pedal travels further but takes less force to provide the same clamping force to the wheel, are you talking about the actual force to press the brake pedal? If so you are wrong it will take more force with a stock brake system to push the pedal to bring a car to a stop. I believe it will travel less overall but take more force. A lot of people have that backwards. +1 with the hill holder or abs pumps being Ts in the brake system, 1 line will go into them and two will go out.
XT6 rear hubs EOI in 5x100 & 5x114.3 ?
D3F0 replied to dfoyl's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Newer higher off set wheels fit actually pretty nice on our older Subaru's. If you lower the ride height they fit pretty snug I wish they had a lower offset to bring them out to our fenders/ my fenders more Also +1 for the lug nuts comment. They should bolt right up you can flip the trailing arm over onto the other side to make it clear the actual tire on the inside. I dont think spacers are really needed it would deff help with "hella flush fitment" though lol.
