nitroman58
Everything posted by nitroman58
I want to replace the rear view mirror with compass and auto dim in my Forester. The Subie part # is H501 SSA101. Could anyone tell me how to remove the old mirror? Since the new part is the same as the old one, I would think thatI could just use the same cable. Is that correct? It looks like this car uses the non standard "cam-lock" mirror mount. Thanks
I am looking for a jack to do an occasional brake job on my 11 & 16 Forester's. My old floor jack only goes up about 13", which works for a sedan but not an SUV. I prefer to have something separate than the jack provided by Subaru. It looks like Harbor Freight has the best selection for my needs. There is a 2 ton floor jack. Obviously, I do not need or want low profile for these cars. Thanks.
Back in April of this year, the dealer rebuilt the short block on my 2011 Forester because it failed the oil consumption test. The car seems to be running fine, but then I notice that there is a burnt oil smell after I shut the car off. So in July, the same dealer takes the car in for another week and to repair a leak in the front crankshaft oil seal. Now, I do not get the burnt oil smell, but the car leaks oil. The oil leak seems to be coming from the front of the passenger side. I call the dealer to mention this, and they tell me that if it is coming from the short block they will address, otherwise it is my responsibility. The car did not have an oil leak to begin with. So to summarize this problem, I start out with an oil consumption issue, and now have an oil leak issue. This whole issue is getting very frustrating. On one hand, they did all this work at almost no cost to me, and the car is running great, but now I have oil leaking from underneath the car. Should I take the car to the dealer to see what they say, or should I contact Subaru at this point?
If they're covering the repair why does it matter what it costs? Yeah, I guess your right. It's just annoying, that I have to take it t get it fixed, and go back there to get reimbursed. It's the time issue. I am due for inspection in March, so I made an appointment for both. Even though Costco does free rotations, I may just do it myself. The jack that I have is not quite tall enough for that car however.
Over the summer, I bought a new set of tires for the Forester from Costco. Today, I went back for a tire rotation, and the guy in charge told me who ever put the tires back on the car cross threaded 2 of the lug nuts. They had to break the lugs to get the tires off. Apparently, they said that the technician may have put the lugs in the gun before starting the threading on the car. They said that they would reimburse me on the expense. What do you think this would wind up costing? Do you think it is worth going back to dealer for this? I am concerned the other lug nuts could have damage too. Thanks
The right front brake was squeaking, so I took a look at the what was going on. It looks like something must have gotten between the pads and rotor, and caused some scoring. I called my mechanic and asked if they could grind them. He said that they just replace rotors these days. I was looking at rotor prices on Amazon, and they are fairly reasonable. Does it seem like replacing them is the best option? I have done pad replacement before, but have not done rotor replacement. I was watching a few video's on you tube, and the job seems pretty straight forward. I would guess that it worth changing the pads even if they do not need them? Thanks.
After dodging the issue of the P0420 code for about 8 months, my son's car really starting to run terribly. I wanted to find out if there are any aftermarket catalytic converters that someone would recommend. I want to get another 2 years out of this car. I have heard from one mechanic that the aftermarket converters are junk. It would be hard to justify spending the money on the Subaru brand, since his car is probably worth that amount. The car is not running well at this point, so I have to make a decision this week.
So far, I have 45,000 miles on the original Yokohama Geolander tires. About 6 months ago the tread depth was 5/32" so I may be looking for tires over the next few months. I have been really impressed with the Yokohama Geolanders, and my only complaint is that I have had a flat which was been plugged twice. At my Costco, they do not carry this brand, but they do carry both the Michelin Defender, and the Michelin Primacy MXV4. I have found the Michelin tires to be be very good as well. I last had the MXV4's on a Honda Accord and Civic. Has any one put the Michelin MXV4's on their car? Any comments otherwise? Thanks.
