overkiller
Contact Methods
Website URL
http://
Location
Mesa AZ
overkiller's Achievements
Member (2/11)
10
Ecology on 27th ave. and Buckeye seems to always have a few Soobs laying around. First time I found pug wheels there though. You're in Iraq? Be careful man, thanks for your service.
I was at Ecology in Phoenix earlier this week and there was a peugot with 14" steel wheels, and a Turbo 4x4 with complete rear discs. No idea if they're still there but I thought I'd pass the word. Oh yeah there was a nice clean 4x4 hatch there too. Travis
Will a stock EA82 clear 27s?
overkiller replied to overkiller's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for the info. I NEED tires bad so I'll probably trim to fit. My car is pretty beat up anyway. Does anyone have any pic to share? Most of the lifted soobs I've seen have been the early ones. Thanks Travis -
I know this has been covered before but searching didn't yield any clear answers. I have an '88 GL Wagon and a set of 14" pugs. I'm planning on getting some 27x8.5x14 Kuhmos, but I don't know if they'll fit stock. I'm not shy of a bit of trimming but I'd rather not lift it, at least right away. If anyone has some pics of a stocker with bigger tires I'd love to see them. Thanks Travis
Horrible noise, tranny or CV?
Awesome thanks for the info. I'll take a chance and put the new motor up to the old tranny. -
2.2L into 88 GL Wagon?
FYI looks like a EA82 clutch is 200mm and a EJ22 is 225mm. Centerforce make a dual friction for both applications. However it appears that the splines are different too. 24x1" for the EJ22 and 21x7/8" for the EA82. I'll have to do more research to confirm this. Travis -
I too am curious about what the D/R trannies can hold up to. But having looked at the options today it seems the easiest solution would be to make an adapter and modify the EA82 flywheel like the rallyjusty fellow did. A good aftermarket clutch i.e; Centerforce should be able to handle the power of a N/A motor no problem. However if you decided to go turbo grafting on the entire bellhousing to run the larger clutch seems like a good idea. I'm not too concerned about blowing up the tranny, I don't do many power drops and they are plentiful in junkyard. I could always go AWD if I blow up too many. I'd love to hear from those with expirence though. I'm going to make some calls this week and see what I can find for a donor motor/car. A tweaked EJ22T would be sweet:banana:. I could see my wagon with 4 ATC paddles carving bowls at the dunes:cool:. That'd be worth the effort. -
new t-case possibility *UPDATE*
overkiller replied to bushbasher's topic in Old Gen.: 80's GL/DL/XT/Loyales...
FYI there are gearsets for the Sami cases down to 6 to 1 and I heard rumors of ever deeper ones being tested. This is probably overkill but the high range gearing is lowered as well. Great for compensating for bigger tires and lousy R&P gearing. Travis -
Here's what a sami looks like. I think you got them down in OZ but they're different from a rocky. Travis -
Thank you, thank you, thank you, that's exactly what I wanted. I searched but I didn't go back far enough. This swap looks pretty damn easy and everyone raves about the reliability of the 2.2l. I need to put together a price list and see if rebuilding the roo makes sense. -
My car's dead right now but when I last drove it it was making a horrible growling sound when decelerating. Accelerating or steady pace was fine but if I let off the gas or downshifted it would growl. I know my front CVs are a little dry so I'm hoping that's the problem. I checked the tranny fluid and it looks good with no visable metal floating around. Has anyone ever had this problem before? I'm thinking about rebuilding my car and don't want to get a new tranny too. It's an 88 dual range wagon BTW. Thanks Travis
Do these adapters exist or would it be one-off? Do you have any pics of the welded bellhousing? How has the EA82 tranny handled the added power? I'd really like to keep my dual range tranny if possible. Any exhaust issues or is the same basic idea on the 2.2? Thanks for the info I've been researching all day and it looks like a good plan so far. Travis -
I'm currently thinking of rebuilding my dead Subaru but I really don't want to spend the money and time to swap in another EA82 and have barely adequate power. I've thought about the EA82T but the lack of cheap turbo parts cars around Phoenix would make that an expensive proposition. Plus I'd be stuck with either a high mileage junkyard unit or a $$$ Jap motor. I was wondering if anyone has ever swapped in a newer 2.2L instead. I'm pretty sure I can get a low mileage 2.2 for less then a Jap motor, and 130hp sounds about right for pushing bigger tires and camping gear up mountains. So I've done engine swaps before and I'm familiar with all the little issues that come up I'm just worried about the big ones. Will the 2.2 physically fit into the engine bay? Will the 2.2 physically bolt up to my dual range tranny? Are there any issues that make this swap impossible or impractical? Does anyone know about the interchangablitity of the clutches and accessories? I'd appreciate any help on the subject. Thanks Travis
Has anyone ever expiremented with a Samurai t case? They can be geared nutty low and way strong for their size.
