Everything posted by JP147
JP147 replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for the advice. It would be good to clean out all the carbon, but I have heard different things about it. Some people have said to use cleaners like that, others have said not to and to only clean the carbon off the pistons when they are out of the engine. For now I will reset the idle because the weather has cooled down and dieseling should be less of a problem.
I have a Weber 32/36 on my EA81 and it was set up pretty good and it would work at all throttle positions. When the hot weather came though, it would idle all over the place and diesel indefinitely when the ignition was switched off. I leaned the idle mixture some so that it would idle better when hot and doesn't diesel most of the time. The problem now is that as soon as the secondary throttle starts to open, it is too lean and wants to ping when it is warm. With just the primary throttle it runs fine though. I have already eliminated all vacuum leaks, retarded the timing as much as possible without losing performance (about 5 before TDC) and disconnected the vac advance (it didn't work anyway). Is there an easy way to fix this issue? Thanks.
It's been a while, but recently I have gotten some work done. Working UHF radio 2" lift kit And a new set of Dynamic wheels with an old set of 27" BFG A/Ts
South Aus is a pretty good place apart from most of the 4WDing here being tresspassing. It is not like other states where there are open forests everywhere. I am glad you like my handiwork, I am new to this sort of thing. In the future I might make the filter box bottom out of steel and grind the welds flat, then paint it so it looks factory. My thick rubber shifter boot was restricting the gear stick movement, so I bought a leather one from the shop that is supposed to go over your normal boot as a decoration. I cut the elastic out of it and clamped and glued it on and it works much better. I also thought the diff might be vulnerable when I do a body lift so I put on this bash guard from Crossbred performance Also I found that the underside of the car is infested with redbacks.
Thanks, I don't plan on selling this one. I live in South Australia. Here is the Weber swap I did Original: The old carb had bad vacuum leaks all over and I don't think the vac operated secondary worked much. Leaky old Hitachi and a new Weber Adaptor plate from Redline. My EA81 has the big manifold, so it uses the same adaptor plate as an EA82. This was my solution to a throttle cable bracket. It was only supposed to be temporary, but it worked too well so I left it like that. When I finished, all was well for a while. Then the weather started to get hot and the engine started to run poorly. The air it was taking in was too hot and even the filter paper was untouchably hot. So I made this: That's motorboat insulation glued onto the bottom. This air box has worked very well at keeping the intake cool and the engine runs a lot better in the heat. It is only temporary though, when do a 2" body lift I should be able to fit an air filter box adaptor and use the original air box.
This is my Leone wagon I bought a bit over a year ago. It was not the cheapest, in the best condition or in the same state, but I decided I wanted it so I flew there and drove 600km back with it. It currently has about 270,000km on the odometer which seems young for an EA81. Managed to pass the inspection in my state on the second try. How I bought it: I then took off the plastidip and stickers, sold the subwoofer, and put in the original steering wheel. Tried some bigger tyres, they don't have much clearance without a lift kit: I got some Speedy wheels but they are not very circular so I have a set of genuine Subaru ones that I will paint and put on later. The sun visor was $14 from a junk yard and it installed without drilling holes. I cut and bent some chome trim from a Datsun 910 and it clamps the visor on. It also holds the original trim which was falling off. This was after going on a 1,200km drive north I like this guage, I wonder how many more lights are on it
New here from South Australia
JP147 replied to JP147's topic in Meet n' Greet. Your USMB Welcome Center
It was a fun road to drive. A lot of big guys had their fun earlier so the ruts were very deep in some places but it got through ok. -
Hello, I am JP I have a 1984 2nd gen Leone as a daily which I have owned for over a year now. It is a work in progress and there is a lot I plan to do with it over time. I chose it because I wanted something reliable, cheap to run and with 4wd.
