bulletproof
  • Gender
    Male
  • Location
    tulsa ok
  • Referral
    chrome
  • Biography
    ive always wanted a brat..now i have one.
  • Vehicles
    79 brat
bulletproof's Achievements
Advanced Member
Advanced Member (3/11)
7
  1. my 79 brat started smoking..but only on deceleration..when idling or under power its ok,,when i let off the gas it puffs smoke... it doesnt have the stock dip stick in the motor,,if its over filled with oil could it be causing the smoke? it seems to have the same lack luster power as before..
  2. is there a chart somewhere showing what cars came with what motor/trans. i really want to swap in bigger motor and dual range trans.. all the ea81 ea 71 ej22 is spanglish to me.
  3. im hoping to do a motor/trans swap at the same time..
  4. we did some brush clearing today where we hunt,, it fits on most of the ATV trails,cant wait to get a dual range trans .
  5. while looking for some 4x4 axle stuff i found these subaru parts,, was told he thought they where from a brat or maybe a wagon,,all the info he had,,the nut holding the hubs on does not have a cotter pin like my 79..any ideas?
  6. its back on the road.. replaced the hub and wheel seal..while it was down i replaced the drivers outer door handle, and cleaned up under the hood a little..gonna drive it around and retorque and on to the next project.looks like a heater vent door is stuck open ,its letting in cold air while driving..and the fan is making noise.
  7. im going to build one. but im going to extend the area where the frame brackets meet the bumper so i can add D-rings..maybe some light tabs and a winch mount.. could you measure the tubing OD?
  8. ive been looking online and have been seeing brats with a pretty heavy duty looking square tube front bumper ,does anyone know what size the upper tubing is? and where could i find a rear hitch like the one shown?
  9. ive was a professional mechanic for 20 years,and a part time builder/fabricator (drag cars/ off road racers )since 2006.. ive spent more time on places rockauto and at autozone then ever before... theses little cars arent the easiset cars to find parts for... the learning curve is pretty steep.
  10. when ordering parts, im now ordering 2 of what i need,,odds are i will need it for the other side.,,i hate letting the car set while waiting on parts ..
  11. 80s jeep cj's had a 2 piece rear axle shaft.. one thing we did when installing new ones (when customer wouldnt spring for 1 piece axle kits), after we installed them we would have the customer bring it back in after a few days and we would retorque the nut..when i replace the hub i just stripped im going to retorque after running it a day or 2..
  12. on inspection,the splines are gone in the drum,,shaft looks ok. ,,there where new brake shoes and wheelcylinders installed ,, i guess they didnt get the retaining nut tight enough?
