yohy
About yohy
- Birthday 01/01/1950
Contact Methods
Website URL
http://
Location
The Great State of Maine
Occupation
no worka....
Vehicles
'97 LL, '03 RS, '04 FX
Recent Profile Visitors
yohy's Achievements
USMB is life! (4/11)
10
I would suggest reading through the following: http://www.subaruforester.org/vbulletin/f88/c-compressor-clutch-95352/ and yes, there are four pages. It seems the clutch on the a/c wears and when the gap exceeds spec it will fail to engage. The solution is to pull the clutch and remove shims. I did this two years ago and solved the problem (fingers crossed). Oh, I did a recap of my experience on post #39.
Check out this post: http://www.subaruforester.org/vbulletin/f88/noise-back-13202/. According to ferret (#7); "This is common. Remove your grill and unplug the sonealert (beeper). It's mounted front and center to the center upright bracket. Dry out the connector and apply a coating of dielectric grease to it and put it back together. Some moisture, salt ( allowing conduction ) or other matter allowing the water to conduct, gives a low resistance path to the ground. So the sonealert makes a low volume, high pitch noise until the connector drys off again." or this post: http://www.subaruforester.org/vbulletin/f108/hello-help-25903/ again ferret to the rescue: "Look in the manual for replacing one of the bulbs in the headlight. It has How to remove the grill. The 'sonealert' ( Beep Beep ) when you lock the doors has a high resistance to ground thru it's connector from salt and water. It's mounted front and center behind the grill, on the center vertical upright. Simply disconnect the connector, clean it thoroughly, coat it with some Dielectric grease, and put it all back together. Common problem .... IF you have GOOD Young Ears !!!! I can no longer hear the high pitch when someone comes to me with the problem."
To quote post #6 on this thread (http://www.subaruforester.org/vbulletin/f88/ac-fine-till-its-hot-57077/): A common problem on all compressors w/ on-demand clutch is failure of compressor to engage due to wear of clutch plate, causing clutch plate gap to become too large. This gap results in coil magnetic field being too weak to pull the plate in against the spring. You can verify if this is the problem by rapping the clutch plate sharply w/ a stick when AC should be running. If the clutch plate closes and AC works, you've verifed that clutch gap is too large. Fix is easy also. Remove clutch plate (usually a 10mm head size bolt) and remove a single thin shim from beneath the clutch plate. Measure clutch gap w/ a feeler gauge to verify it is w/i spec, usually 15-25 mils. Also check out this thread as it will contain some valuable how-to steps: http://www.subaruforester.org/vbulletin/f88/c-compressor-clutch-95352/ Hope this helps.
GD, Thank you for your reply, insight and suggestions. My dad, a Georgia Tech graduate who holds a PE license, contends that lack of confidence or understanding tends to lead one to overbuilding or over engineering. With that, as a shade tree mechanic versus yourself, a professional, I tend to over compensate for my lack of experience by being as precise (or anal) as I can. With that, I stress over things like torque specs, while you would just tighten to a known range and be done, I search for the elusive specification. I guess I just have to have more confidence. Thanks again.
Can anyone give me the torque spec for the caliper body to the caliper support. '09 Legacy SE non-turbo. I am working on my son's car and don't have a service manual for this specific car. I have one for the '93, '97, '03 and the '04, but not this one. I have cross referenced to what I have but they seem to vary between 27.5 and 19.5 ft lbs., I would just like to get it right. Thanks.
I did the front struts on my '93 Legacy and all four on my '97. First tip I can remember (it's been a few years since doing the '97) is when you remove the brake lines from the strut, cut the bracket that holds the line, this will save you the hassle of breaking lose the connection at either end of the brake hose to pull the line through the hole in the bracket. Then when you install the new strut, do the same thing, cut the bracket, slip the hose into the cutout and then bend the bracket back. Second is this, if you are using the typical spring compressor it will barely compress the spring enough to free it from the upper/lower spring seats. I had to reposition the compressor a few times to get it right. Lastly when you reassemble, make certain you get the spring seated in the upper/lower spring seats correctly (very self explanatory) and the spring is oriented correctly, flat end is on the top, inclined is on the bottom. I can send you the FSM section on strut replacement if you would like (from my '97 FSM). From what I remember, overall very doable, on your end, considering your level of expertise, should be a non-event.
John, To answer your question #1, list is $242 and can be had online for about $175. Shipping may be an issue so if you can purchase locally..... http://www.trademotion.com/partlocator/index.cfm?action=getLocator&siteid=214077&chapter=ARL7601&appSectionid=2695&groupid=2706&subgroupid=2707&componentid=2928&make=32&model=Forester&year=1999&graphicID=7601310&callout=1&catalogid=2
Try this: http://www.endwrench.com/main.php?smPID=HTML::parts.html then scroll down till you see: For more about Genuine Subaru Maintenance Parts and application charts, click the Icon to the left. it will down load a .pdf with all of the parts numbers, but careful, it's like 12 megs. BUT, it will give you all of the part numbers you are looking for.
cagranitz, rust in this location on the Subarus is quite common, although a bit premature on a 2001. Both my '93 and to some extent on my '97, had rust in those areas. One other trouble spot is the dog leg behind the front wheel opening. The attached picture is what I pulled out of my son's '03 Impreza when I put splash guards on it last summer. I have found this point a catch all for road dirt on all of my Subaru's including the Legacy, Impreza and the Forester. Everytime I wash any of the cars, I direct a strong stream of water into the front fender. As strange as it sounds, open either of the front doors and you will see openings into the front fenders (around the hinge locations), just direct a strong stream into the fender openings. If you have never done this, get ready to be blown away by what you flush out, really.
