Location
Priest River, ID
Vehicles
1979 Subaru Brat
ME123Insanity's Achievements
Member (2/11)
2
Oil weight tips for ea81 with 200k miles
ME123Insanity replied to ME123Insanity's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So, as far as synthetic oils go, which brand do y'all think is the best? Or are they about the same? Btw, thanks for all the replies, really helps. -
1979 Brat clutch pedal hinge worn out
ME123Insanity replied to ME123Insanity's topic in Historic Subaru Forum: 50's thru 70's
It does. When you push the clutch in the box flexes, at least mine does. -
Better late than never I guess, anyway... As you can see my welder reconstructed the hole by smoothing out the area and welding a washer on so the pin wouldn't move around when I pushed the clutch in. This picture shows the clutch pedal (on the left) and the brake pedal (on the right) that pin goes through both pedals to the left side where the welding took place. If you're having trouble, that's where I would start. Hope this helps. -
Like you, I'm also doing a weber swap on my 83 brat. Do you think you could explain to me how to hook up the vacuum lines (passenger, driver side valve lines and PCV valve lines) after the weber is on? Also I hear talk about the charcoal canister but I can't find it anywhere and don't know what it looks like..?
Sure! I should be able to get some up tomorrow hopefuly. My clutch squeaked really bad before it got so bad I could barely shift. Wouldn't be surprised if you're pedal box needs repaired. I'll get some pictures up ASAP. -
Wow! That sucks. I got everything fixed up today though. -
ea71 vs ea81 intake manifolds
I haven't bought the Weber yet, so no. -
Because the stock carb I have is a Carter-Weber and not a Hitachi. I haven't bought the new Weber yet but from what I've read on this site, the Webers need 4 mounting bolt holes on the intake, the intake I currently have only has 2. so that's why I'm looking for a different intake. -
I'm planning on putting a Weber carb on my ea81 but need a different manifold since the Weber doesn't fit on the one I have. Just wondering if an ea71 manifold will fit on a ea81 engine without any problems? Thanks
Ok. Thanks so much! -
Is this something that could be fixed at a mechanics shop?
