Everything posted by jread
Haven't tried yet just running without them till I have time. Weird issue is my interior lights aren't working now... Two map lights won't go on no matter what bulbs I'm using. Must be something weird in the wiring. Dome light also won't come on unless the door is open.
- 190 replies
- Instrument
- Cluster
(and 7 more)
Tagged with:
The gauges are working I must just be really unlucky and flipped them all around when they went in. I checked fuses, connectors, the paths on the circuit board.
- 190 replies
- Instrument
- Cluster
(and 7 more)
Tagged with:
Weird. I didn't think this would be the issue since I switched them side to side and they still don't light on the left. Guess I'll pull the dash off again...
- 190 replies
- Instrument
- Cluster
(and 7 more)
Tagged with:
Managed to do this now half of my dash lights don't work. What did I do wrong!! Whole left side, turn lights, backlight, nothing.
- 190 replies
- Instrument
- Cluster
(and 7 more)
Tagged with:
Been looking into my steering wheel play on my GL but have no idea what to search for. The issue isn't in any of the steering components but the actual wheel shifts from one side to the other in the column. Especially noticeable since it doesn't have power steering. What would cause this? Whats it called so I can search and fix it?
My website, anyone still use it?
jread replied to Numbchux's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Bummer. Going to have to save all those files. -
Difference Between XT6 And GL DR Clutch
jread replied to jread's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for rubbing it in! -
Name this part, small box and relay.
This one is right infront of the wiper motor on the back side of the strut tower. Maybe its not even useful! Seems like the engine will start without it then! -
any Puegoet 505 Turbine wheels for sale?
jread replied to RubberMonkey's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a set of 14s 5 of them. If I acquire the 5 lug parts im trying to I'll have 5 15s as well sometime in the new year likely. -
Anyone know? Got a new clutch coming soon don't want to put it all in to have to take it all out! -
Someone? Anyone? -
Going to get the LUK one, have read quite a few good reviews and its quite a bit cheaper! Thanks for all the info. Guess I'll be sticking with regular strength. -
They have a 24 spline count for the go listed on rock auto. I guess I'm sol. That excedy is the one I listed but not sure what that spline count is. Is it of the input shaft? I definitely need the 24 then? Also there is a luk with the same part number thats 60 bucks less. Lots of people seem to recommend them might as well give it a try! -
Seems like the box is a resistor but not sure what for.... Hoping its for something I don't need but it doesn't seem like it will be... -
Whats different about the step? Is the 24 spline vs 21 spline better? -
Also any preference for Brute Power vs Excedy vs Beck Arnley? -
Looking to buy a new clutch and just wondering what the difference is for the xt6 clutch. I've ej swapped my car so looking for a bit better clutch. I was looking at this one on Rock Auto which has 24 Splines vs the normal 21 for the dual range. Is this the only difference for the XT6 Clutch? Mostly asking as this one isn't listed under XT6 but the one that is has 24 splines and thats the only difference I can tell. EXEDY 15008 Info 4WD; Disc mm 225; Disc in 8-7/8; Splines Dia 1; Splines 24 (Only 2 Remaining)
Got a new wiring harness for my loyale and found two plugs that aren't on there. One goes to a silver box and the other to a relay attached to the box. They are located near the diagnostics plugs on the driver side of the engine bay in a 93 loyale. Anyone know what these are? Can post a pic but hopefully someone will know before I get around to that.
Sounds like I should probably stick with my tires, and maybe do some trimming to fit something a bit bigger but over 29 is just going to break everything. Also not mall crawling. Putting it over some decent obstacles to go camping but still need to DD it. Right now I have a loyale with 215/75r15s may do some extra trimming/ banging to get the extra width but don't know if I'll need it.
Was wondering what the biggest tires people are putting on there subies and what are the weak links in the system? Do you break axles? Rubbing lots? Is it hard to drive on the highway? Does it look sketchy? I'm planning on putting them in an ej25 swapped gl with a 4" lift. I have 215/75r15 wondering if I can get away with bigger. Might even consider getting a 6" if the car will stay steady on the highway.
86 Carbed EA82 Cuts out while driving up hill
Bang on. Thank god I didnt take the carb apart. Po had a new fuel filter in the back so I didnt even have to pay for it! -
Looking to Borrow some 4x140 Rims/tires
Damn! Thanks anyways... Looking to buy something cheap and used now. -
Bit of an odd request but going to give it one more bump! Can give you a couple bucks or some beer for your trouble!
