montana tom
12
Everything posted by montana tom
We used to have a 1/8 th mile high bank dirt track just down the road. I took an early 80's 4wd hatchback and ran the ea18 engine in the fever four class. I rarely won but I could hit those high banks rite at the bottom and blow by all the 2.5 ford motors ... who would promptly blow rite by me as soon as they hit the straightaway. It was great fun and a bottomless black hole for $ .... Just before they shut down the track I had acquired a early 2.2 & a 2wd auto trans for it . Had to modify the intake to use a 500 cfm holley carb . Used a Mitsubishi points distributor on the back of the head.... home made headers, it was quite the set up . Sadly they shut down the track before I got all the bugs worked out. Everybody is correct these just are not high performance motors until you step up to the wrx/sti . Good luck on the track keep the rubber side down.
Burp your cooling system.A properly running subi should hold the exact same place on your gauge at all times when warmed up. Exception's for extreme temps are ok. A new sending unit could read at a different location but it should remain rock solid ! Burp your system ,if its full maybe your thermostat is failing ? Electric fans working ?
Read a post here a while back. Somebody took an old fuel cap ... drilled a hole thru from the top... attached a hose nipple with silicon ... put a garden hose on the nipple .... sat back a good ways ... lit his cigar... and blew the smoke thru the cap down into the evap system ... where the smoke came out was the bad spot... I have never tried this ... could work...
Rather common unfortunately. several things it can be, all in the evap system. The charcoal canister could be flooded with fuel ... or the valve just behind the canister could be malfunctioning. or the purge solinoid under the hood (probably not) since you didn't mention hard starting. Start at the canister.
Easy way to check the fans is to turn on the A/C , both fans should run. My wife's 01 started heating when pushed hard uphill. a check of the fans showed that the secondary had blown a fuse.. new fuse no more overheat. Your 2.2 is not prone to HG failure (but it can happen) and in my opinion a plugged heater core will not cause an overheat either. You have changed the radiator/ subi thermostat / waterpump... not much left... confirm the fan are working ... if they are, then you can try bypassing the core but order your subaru head gaskets promptly
Nice build, thanks for sharing. I will say that currently I like the look of your buddy's wagon .
- 20 replies
Sounds like fun... throw some of those bikes up on the roof. Mount your rear hitch high for ground clearance. Heck throw a hitch on the front as well ! As everybody has said "It Won't Last ! " But who cares.... your doing this for the hxll of it . Look at some air bags for the rear , airum up if you need more suspension. Larger tires cost more money... forest service roads tear them up. Use whats cheap and readily available. I have heard about dual range trannys for that year coming out of japan.... you could really cruise in low range... HAVE FUN ! EDIT; Oh yea... if you remove the back hatch and drive up a dusty dry mountain road you better have dust mask's for everyone to wear...
- 10 replies
- 1
