montana tom
12
Everything posted by montana tom
Finally got a look at the trans # on the Canadian 02 obw After a little searching "TZ1A4ZCDBA-RM" Is the same transmission used in the us cars. 4:44 differential . I'm curious that if they replaced the instrument cluster to get a mph speedo , then why the Celsius temp gauge ? I'm wondering if the Vancouver , BC market gets mph speedos because of the proximity to the US ??
No on the 3.0 and interestingly enough the speedo is mph with kph in the back and the odometer reads miles. But the temp is in Celsius ...and the under hood sticker says Canadian emissions ? Odd ... I don't have the car here as its sold, so I will have to get the tranny number as soon as I can. I do remember it matches the vin plate #. I will try a goggle on the tranny # asap.
Hi guys; Bought a 02 outback wagon recently. This car was produced in the US but was built for the BC market. I'm wondering about the final drive ratio. This car has lower rpm readings than any other automatic US outback I've driven. 75 mph and its pulling 2000 rpm's... all others run closer to 3000 rpm... Tire size is stock outback 225x60x16 ??? Did produced for Canada outback get the 4:11 final drive , like a US legacy ? All the US outback's seem to have the 4:44 ratio... How can I decode the tranny code or the rear diff. ? With the current set up this car is getting 29-30 mpg ... much better than my MT outbacks that run a steady 26-27 mpg. Customer is wanting a replacement tranny and I want to confirm things beforehand, any help is appreciated !
I would source another crank gear rather than trying another repair. Does the comp show any codes ? In Australia you are offered different options than we are limited to in the US . Twin turbos ... diesel engines ... they even have slightly different names, but they are still all subarus under the sheet metal. I don't think the outbacks here used the coil igniter at all,(i could be wrong) I remember them on 90's impreza's . Many others out there with more knowledge than me about electrical issues ,hopefully one of them can help you.
P1433
montana tom replied to alarmgirl00's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Vapor canister purge valve. Located on intake manifold. Small part, way over priced. The under hood vacuum sticker should show you the location. Look back a few pages here on this forum for a post entitled 2004 obw code 1443 , it will have a picture of the offending part. If you have a wrecking yard nearby I would look for a used part. -
Might check your valve adjustment, in 04 I believe it is .16 intake and .21 exhaust
- 9 replies
- 2004 Legacy
- EJ251
(and 1 more)
Tagged with:
Close enough, I think 105,000 is factory suggested. However midas would NOT be my first choice of a subaru shop. That said, whomever works on it for you, make very sure they are installing only parts made in japan... preferably subaru . Parts with a normally good american name brand may end up being manufactured in china... All the parts must be replaced, not just belt,water pump & seal. The tensioner and all thee idler's MUST be done at the same time. Both cam seals and the ft. crank seal should be done as well. This is an interference motor .... poor quality parts will leave you on the side of the road with bent valves and a big headache dealing with the new repair. I recommend looking for a shop that is used to working on subarus , talk to them first and see what parts they suggest and if they install only high quality Japanese parts.
Had some more evap issues with this car... gota "love" calf. emissions ! No codes and no trouble pumping fuel in , but after filling , it was hard starting and running poorly for a few minutes. A check of the canister purge solenoid showed it was stuck open , a direct vacuum leak from the throttle body to the fuel tank ... No wonder it acted flooded with a full tank of fuel ... it was ! Again a 2004 part won't work properly, it takes a 2005. Luckily the one I need is $60 the other is $95.
