montana tom
12
Everything posted by montana tom
My 2000 obw has 257,000 miles on it and its got the same clutch as when i bought it at 110,000. I had the engine out recently to replace the HG , checked the clutch while I had it hanging ... and put it right back together again. You will know when your clutch slips and as long as you fix it quickly it won't ruin your flywheel .
I spent hours on my 94 looking under the dash for power wires to the windows. If you have no luck finding the your problem under the dash, try removing your driver seat and look under your carpet. Mine had a corroded main power wire from all the moisture that gets held under the carpet on the drivers side.
A 2002, 2.5 will have an 8 bolt bellhousing, yours is a 4 bolt , none of your upper parts will bolt on, as well as your trans not bolting up. It can be done but its more work than your thinking.
- 8 replies
- legacy EJ22 95 96 97 98 99
- ej22
(and 2 more)
Tagged with:
Well # 3 may be the worse one or the first one that the computer is reading. At least it's not that hard to check timing ... well... depending on your experience level , it's not hard to check. You have already tried the plugs, wires & coil, checked compression ... there isn't too much left that it can be. Oh last thought, did you just fill up with fuel ? Could you have water in the fuel filter ???
I agree its the mechanism, and the outside handle does rust up and get sticky, but I have found that inside the door there is a small pivot point that rusts up badly and lubing the outside handle won't make it in to lube that point. Remove the inner panel and work the latch, lube up any moving part of the linkage inside ,sometimes removing them and sanding works wonders. Don't just rely on a wd-40 product , use a spray white lube that will stick around and help keep the rust away.
If you have the donut and the 2 new bolts with springs and nuts, then this is not hard at all. Your car came with a jack to change tires so you can lift it up. Sawzall is not needed ... those old bolts will either unthread or break... worse case if the bolt heads strip before breaking then a hacksaw will cut them enough that a hammer will finish breaking them. The whole exhaust is rubber mounted it will pull away after the bolts are removed. The old donut will need to be persuaded with a screwdriver and hammer to come off, then just stick on the new donut, put in the new bolts and springs , let down the jack and your done! No $70.00 hr and 2 hr drive involved.
Go for repairing the evil you have... give it new head gaskets , you have to buy the TB, idlers & WP no matter what. This way you know when everything was changed , no surprises. As far as running into any problems ... anything you find probably would have needed repair no matter what option you go with.
Find out why that engine is not seating ... BEFORE buying anything else. Something will break if you don't fix it ! Amazing they got the motor mounts to go in with it 1/2" back!
- 8 replies
- ej22
(and 2 more)
Tagged with:
