montana tom
12
Everything posted by montana tom
Ok; Let me see if I got this straight. Your post is slightly confusing. You bought a 99 with bad HG , you repaired it yourself and it worked for a while but now it has gone out again? Then you have a different motor from a wrecked car that you want to use but it will not turn all the way over ? If your looking for a bad head gasket , remove the head and look at the gasket ... you can always see where it blew thru. cracked heads can happen if the motor gets hot enough. Of course if it got that hot the rod bearings are next.
Well I have bought a new rebuilt one thru ebay, over $400 but is in the wifes car has grease-able ujoints and has performed 4-5 years now. So have some of those used ones as well. I have heard mixed reports about the cheaper driveline's most say they are fine a few have said they are not balanced properly. I have never even checked what a Subaru one would cost.
Well I can tell you that the cam and crank sensors can be different between auto and manual trannys no matter which motor you use. And they are very different motors. The 99 2.2 leaves a lot to be desired,it is an interference motor and it has oil use issues ... it doesn't hold a candle to the 96 -90 non interference motor. I would get a 2002 -04 2.5 for it.
Every time you are in a parking lot and you see a nice subi , ask where they get their work done. Sooner or later you will locate the hidden subi shop. There will be one somewhere. I know this because, I am the hidden subi shop around here. I get referrals all the time and I hear the same thing. OMG why didn't I find you sooner! Nobody else around here knows how to work on my Subaru ! Why don't you advertise??? Easy I don't need to. Quality Subaru work advertises itself !
- 23 replies
- 2
- oil leak
- piston slap
(and 2 more)
Tagged with:
Haven't cleaned a cv and done a boot in many years now. On a personal vehicle that you see the boot get ripped and disassemble that day you most likely can save the joint. After that I change the axle. When a car rolls in my shop now, no way could I afford to change boots. ( I did it all the time in the 1980's) around here with gravel roads the damage is already done before they can drive it here. To answer your question... flush with clean solvent and blow out with clean air. Wear a face shield ... no fumes to speak of but lots of splash.
Burned valve and it would be shaking at idle , most likely show a misfire code. Compression test would show that. So far in over 30 years messing with subarus and I personally have not seen a dropped guide, even when I was dirt circle track racing and seriously over reving at times, the heads always held together... more than I can say for a few pistons though .
On an 00-04 . The abs sensor is magnetic , mounts thru the hub and reads directly from the axle. The ring heartless showed is the 90's version, the 00-04 have it built on the cv axle itself. . Pretty sure the "newer " ones are the same . It has to read a turning part to know what the tire is doing.
- 9 replies
- cv axle replacement
- brakes pulsing
(and 3 more)
Tagged with:
