nvu
13
Everything posted by nvu
dash lights
nvu replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You could, though depending on the led and resistor picked, it may not light up at all if there's a fault or light up all the time when there's no fault. It might not detect the case of the alternator sending overvoltage as the led doesn't light up in reverse current situations. -
Guessing it was making burning smells before? If it did and only the disc was replaced, chances are the flywheel and clutch cover are uneven. You might be experiencing clutch chatter. Maybe it's uneven clutch material from the prev clutch, and would go away over time. The viscous coupling portion could be completely failed and you'd never notice it in straight line. It doesn't cause the issues you're seeing even if failed and you can still drive it. Center diff/visc coupling can be checked by driving in figure 8's, a worn one will feel like it grabs with tension then lets go over and over. If the center diff portion starts failing, you'll hear an awful noise and likely lock all 4 wheels when it completely fails. My 98 outback sport has chatter only when inching along in stop and go freeway traffic and things heat up. To get going from a stop, I blip the pedal to 2k and release the clutch as the rpms falls, gets it going with no chatter. Press the throttle again once the car starts moving. It's a smaller car with a cable clutch so it's all or nothing when it comes to grab point range.
you did the ej22 already so most things are the same, here are the differences: ej205's came with plastic cam pulleys, also the cam bolts need allen key's. they are a pain most of the time, look up some videos on how people get them off beforehand. I've removed rounded off bolts with a bolt extractor. can't heat the ones with plastic cams without weakening them. not much you can do with the turbo. check for turbo shaft play when it's off, the exhaust housing likes to crack around the wastegate port. it's safe to continue to run it if it still seals, just not optimal. crank bolt is on much tighter than ej22, 133ftlb instead of 95 in the ej22. if you don't have the crank holder tool loosen it with the engine in the car and someone standing on brakes in gear. headbolts are reusable if not corroded. wipe off and clean lightly, no wire wheel. if there's no corrosion it's safe to reuse. consider reringing the pistons since you're already in there
Guessing the mating surfaces aren't flat anymore. Next time you do an oil change, lay the old washer on the table. It should be completely flat and uniform. I've seen weirdly deformed ones where the center hole is no longer round. If the pan was still good, the crush washer eventually flattens down to look like a regular washer.
I agree with ido, leave it as it is. at this point, changing it might cause more leaking. we don't know if stopleak had been tried on it before; likely yes. note on "stopleak" type products, they contain chemicals that soften and expand nitrile orings. use them once to see if it helps, if you keep using more eventually the orings will turn into a gummy mess.
more importantly, get into the habit of checking your oil level when you get gas. these engines tend to burn oil when they get older. you want to know if it's something troubling like having to add 1qt of oil every fillup. if doesn't burn more than 1/2qt between 3000mi oil changes, you have piece of mind and can check less often. it's game over when you see that oil light on your dash. betting your mechanic friend would have plenty of horror stories on this.
The computer has no control over the battery light. From the 2pin connector, one wire goes to the battery lamp -> fusebox -> positive rail. The other wire goes battery positive as directly as possible. If the voltage the alternator puts out is too high or too low compared to the positive rail at the fuse block , the light comes on from differential voltage. One wire should have some resistance to the positive battery. The other should have very little resistance.
- 12 replies
- 1
- battery light
- brake light
(and 1 more)
Tagged with:
Check and clean the 2pin connector carefully. Replace if needed. That connector is the sense circuit, one wire runs as directly to the battery as possible, the other goes through fuses, dash circuit, through the dash battery lamp. Oldschool subarus have a light bulb for the battery for resistance and the charging circuit depends on that. The alternator uses the voltage differential between two wires to regulate power. If the connector is dirty or wires are corroded, the extra resistance will force more voltage. Yeah and unplugging it completely disables the charging so the lights turn off. No computer involved. The light turns on if there's a big enough voltage differential. No idea how newer ones work, they have leds and digital gauges.
- 12 replies
- 1
- battery light
- brake light
(and 1 more)
Tagged with:
NGK plugs already have nickel alloy coating on them. On aluminum you can install them dry. I do. There's very little room to access the rear plugs, I usually use a plug socket -> short extension -> tiny wobbler coupling -> wobbler extension -> wrench. Outside temp sensor would be on bumper, lower opening near license plate.
looks like it's a push in clip from the picture. i'm not sure. you have the new assembly already. cut into the black area of the old assembly until it frees up the wiring.
- 1 reply
- tail lamp
- tail light
(and 1 more)
Tagged with:
not sure how it would end up on a worn set, on a new set when i pushed out the hub again it was very little effort on the press, like only moderate finger pressure on the lever. no way to tell until you do it, if it binds and you have to press hard to pop it off, it's likely too late... and most of the time that's the case.
