nvu
    14
Everything posted by nvu
  1. Guessing the mating surfaces aren't flat anymore. Next time you do an oil change, lay the old washer on the table. It should be completely flat and uniform. I've seen weirdly deformed ones where the center hole is no longer round. If the pan was still good, the crush washer eventually flattens down to look like a regular washer.
  2. I agree with ido, leave it as it is. at this point, changing it might cause more leaking. we don't know if stopleak had been tried on it before; likely yes. note on "stopleak" type products, they contain chemicals that soften and expand nitrile orings. use them once to see if it helps, if you keep using more eventually the orings will turn into a gummy mess.
  3. if you haven't touched the axle nut, likely the dust shield rubbing on the new rotor. pretty common on subarus with disc rears. you can bend it away or grind a bit of it off. or just run with it until the noise goes away.
  4. Why not a bluetooth to fm adapter that plugs in the lighter? Some even have aux input. https://www.google.com/search?q=bluetooth+fm+adapter+car+aux
  5. more importantly, get into the habit of checking your oil level when you get gas. these engines tend to burn oil when they get older. you want to know if it's something troubling like having to add 1qt of oil every fillup. if doesn't burn more than 1/2qt between 3000mi oil changes, you have piece of mind and can check less often. it's game over when you see that oil light on your dash. betting your mechanic friend would have plenty of horror stories on this.
  6. Try spinning the wheel with one hand and grabbing on the shock spring with the other hand. It's easier to do with both tires off the ground. My guess is something wrong with the bearing causes the tonewheel to rub on the knuckle. It's probably disintegrated enough to not make noise unless braking.
  7. more importantly, why is it groaning. if it's not brakes related it's probably a failing bearing or loose axle nut. figure out the groaning issue first, remove the abs sensor from the hub see if it stops groaning
  8. Compression test would answer the bent valve question. Throw it back on the car enough so you can hook up the starter and do a compression test on it.
  9. you can rule out clutch fork and any clutch related issues by trying to get into gears with the engine off. if it still doesn't get into gears only other thing you can check is the shift linkage. otherwise it's an internal issue with the trans
  10. The computer has no control over the battery light. From the 2pin connector, one wire goes to the battery lamp -> fusebox -> positive rail. The other wire goes battery positive as directly as possible. If the voltage the alternator puts out is too high or too low compared to the positive rail at the fuse block , the light comes on from differential voltage. One wire should have some resistance to the positive battery. The other should have very little resistance.
  11. Check and clean the 2pin connector carefully. Replace if needed. That connector is the sense circuit, one wire runs as directly to the battery as possible, the other goes through fuses, dash circuit, through the dash battery lamp. Oldschool subarus have a light bulb for the battery for resistance and the charging circuit depends on that. The alternator uses the voltage differential between two wires to regulate power. If the connector is dirty or wires are corroded, the extra resistance will force more voltage. Yeah and unplugging it completely disables the charging so the lights turn off. No computer involved. The light turns on if there's a big enough voltage differential. No idea how newer ones work, they have leds and digital gauges.
  12. NGK plugs already have nickel alloy coating on them. On aluminum you can install them dry. I do. There's very little room to access the rear plugs, I usually use a plug socket -> short extension -> tiny wobbler coupling -> wobbler extension -> wrench. Outside temp sensor would be on bumper, lower opening near license plate.
  13. Probably same as MEK around here, great for cutting oil/grease, that stuff will melt rubber and some plastics. It leaves a residue so go over everything with brake cleaner just before putting on rtv.
  14. I'm fairly sure Aisin doesn't make the idler pulleys, esp the cogged one. Have them take a picture to confirm.
  15. looks like it's a push in clip from the picture. i'm not sure. you have the new assembly already. cut into the black area of the old assembly until it frees up the wiring.
  16. not sure how it would end up on a worn set, on a new set when i pushed out the hub again it was very little effort on the press, like only moderate finger pressure on the lever. no way to tell until you do it, if it binds and you have to press hard to pop it off, it's likely too late... and most of the time that's the case.
  17. did you forget to put the outer seal in after pressing in the hub? i did one time. had to press it out and reassemble everything. not sure how long lasted, many years though. this was a new bearing.
  18. The damper rarely fails, on a 2010 I doubt it's the culprit. You could get away with removing it completely and bridging the lines. You're describing the fuel pressure regulator, it's near the injectors and has a third port that goes to a vacuum hose. Unplug the vacuum hose while the engine is running. It should not have fuel coming out. Fuel pressure probably doesn't hold overnight, but it should hold for a couple minutes right after key off.
  19. update: took the car with the 4.44 box out today. it does 3000ish @ 65mph and a bit over 3900 @ 80. so no idea what transmission they put in yours. it might be one of those close ratio ones for rally.
  20. I got mine at an importer, it's from a jdm forester but not sure if turbo. I could affirm that 5th gear revs high like he's seeing. But again to the OP, the fixes are fairly involved. The 5th gear set parts were ~$200 from the dealer when I did mine around 2012. Labor might be more than that. It's working, drive it.
  21. likely got the 4.44 trans from the forester. i have one on my impreza it does around ~3000 at 65. both trans and rear diff need to be swapped to match. not really a cheap fix, you could put on bigger tires to offset the rpms
  22. Makes sense, looking around seems like 1-1.4oz is the norm for compact car compressors. The oil that came out was quite yellow, but transparent. The hoses and cores are new so there's no oil in them. Might as well drain out what's left in the compressor and readd with new oil too. Thanks
  23. How much oil is in a new compressor for 02-07 era imprezas? The car is an 03 impreza. The system hasn't been working so I couldn't cycle the compressor. Almost everything except the hard lines have been replaced: -condenser/drier -evaporator -TXV -soft hoses -compressor Dumping out the old oil in the compressor, there's barely any and it's thick black. I've gotten a used compressor. Dumping the oil out of that one there's a lot more of it, but clear. Looking at the service manual doesn't show how much oil to add to the compressor.
  24. The one behind the crankshaft never wears out, it can be reused. You'll see the cogged idler next to the water pump. All the idlers lose grease eventually, they'll probably fail eventually. You could probably limp it home if it was any smooth idler. Failure of the cogged idler usually skips timing or snaps the belt entirely. Take your time and gather the right parts. The timing belt almost never fails on these engines, and with lower revving sohc it's likely your idlers are still in good shape when 110,000 rolls around.
