nvu
    13
Everything posted by nvu
  1. i've had good results welding plastic bits back together with a plastic soldering iron. picked up one at harbor freight, it has a triangle tip and seems to lower heat point than standard soldering irons. I've fixed door cards, headlight tabs, window switch panels, etc... it took some time fiddling with techniques until you get to feel on how to melt plastic just enough to weld and not too much that it becomes brittle. if you get the hfreight kit, the black strips they supply is hot glue and not plastic. you'll have to get a separate plastic rod welding pack or just use whatever spare plastic bits you have as welding material. i've found the black abs plastic from old dell lcd monitor covers to be really good for this.
  2. looks like you already have the bracket, oops it's missing a bottom bracket for the compressor. for the tensioner, you could skip it all together and get a stretch belt directly from the crank to the compressor. here's a diagram, it's 73611 https://parts.subaru.com/a/Subaru_1998_Impreza-22L-MT-4WD-Outback-Wagon/_54104_6022881/COMPRESSOR/G10-732-02.html
  3. Definitely pull clutch hydraulic then. If that's the trans, it will cross reference with 02-05 usdm wrx. You might wanna double check the new clutch and clutch cover to see if they match. If not, the exedy ksb-03 kit is oem replacement for that trans.
  4. Looks like you have a pull style clutch. It's the same bearing for all 5mt pull style transmissions. Here's the part, use the crossreference to find it elsewhere, should be no more than $50 last time I got one. https://parts.subaru.com/p/Subaru_2002_Impreza-205-5MT-4WD-WRX-Wagon/BEARING-CLUTCH-RELEASE/49239161/30502AA130.html
  5. sounds like the clutch doesn't fully disengage when cold. with the engine off, is it easier to shift into gear? if so, likely nothing wrong with the transmission. bleed the lines and check the pedal adjustment. if it's a push clutch, sometimes the fork cracks and bends causing these issues.
  6. unplug the switch, see if it goes away. if not, look for the tail/illumination relay, pull that out. if that doesn't turn it off, something aftermarket or is wired different from factory. This is from a 98 impreza, similar setup as legacy
  7. it just sits in there spring loaded. the tension is enough to keep it from backing out. these aren't high torque bolts so that should be good enough
  8. It's water getting past the rubber boots and collecting in the hole. Just pull the plug wires and look at the clamp inside them. Might as well pull the plugs and inspect while you're there. Might be a good idea to blast the holes with compressor air before taking out the spark plugs. I found a picture, see the wavy areas where the plug wires are. Water likes to collect up there and eventually makes it inside the hole.
  9. My ej22 was acting up weeks ago when the rain was constant in socal. It had similar issues of running fine with gas and idling poor. Turned out there was water in the spark tube and it corroded the connector so it didn't clamp on the plug tightly. Worth a check if you haven't done so.
  10. Sender port is the simplest for a temporary install if you want to diagnose the problem. You could remove the alternator belt and swing it out of the way. The car could run for an hour before batteries get low. It's likely just the sender, the engine would already make bad noises if it were actually low pressure while driving. With the engine warmed and real pressure gauge attached, rev it a bit and see if the pressure stays good.
  11. Not sure on 99's, I had a similar issue on an 03 and it did turn out to be the relay. For the 03 it was next to the fuse box on the drivers side, had to remove lower dash to access it. It was a cylindrical relay.
  12. Maybe check the timing tensioner? A failing one would make valve knocking sounds.
  13. i especially enjoy that this causes cancer, birth defects, and other reproductive harm
  14. remove the lower dash, should be only Philips screws, unhook some switches attached to the plastic panel. then if needed you can also unhook the fuse box from the frame, it's only some 10mm bolts/nuts. no need to unhook anything, but should give plenty of room
  15. you have the version where the 2 bolts are external to the tank. i don't think it needs any washers. middle one. the one i have the bolts are internal to the tank, directly touching the fluid. the washers go inside between the bolt and the internal tank bottom. right one. rtv wouldn't hurt, just give it a day to set. it really shouldn't need any to seal. thinking that bottom plate is tweaked, check that it's flat and square. If the crush washers helped, maybe the bolts are too long and not original. Here's the link to the pic https://parts.subaru.com/a/Subaru_1996_Impreza-Outback-Wagon-22L-MT-4WD/_54100_6028409/POWER-STEERING-SYSTEM/G10-346-02.html
  16. If it's just at the reservoir I'd rtv the mating surfaces. The copper washers are for the newer style reservoir.
  17. push the piston 80% of the way into the block, tighten the compressor a bit more, tap around the edges so the compressor gets into the chamfer, tap the piston in
  18. are you using the ratcheting sleeve compressor? place the piston face up on a flat surface, place the compressor over it and lightly tension it down making sure everything remains square. pick both up and put it them on the block, tap it so the skirt protrudes into the block and the rings are around the last tension band. lightly tap around the top of the compressor and tension a bit more. make sure it's squared and centered. the piston should slot in with moderate tapping.
  19. Center diff takes the brunt of the mismatch. In a safe place, drive in figure 8's and see if there are any odd noises under the car. Center diff failures are usually a binding/release feeling, then quick knocking sounds, then catastrophic failures that could lock all 4 wheels. It's probably safe if there are no noises or binding.
  20. For composite gaskets it wouldn't do much as they fail the rubber/graphite breaking down and eventually coming apart. Moving the thermostat to the top has the risk of it never opening if there's a pocket of air big enough to dry it out.
  21. R180 only found in sti, and mated to the 6spd. Will need bigger axles and the bigger hub knuckles from an sti of that era. To drop in and replace an r160 you'd have to frankenstein some axles and possibly slot out the driveshaft flange. I'm only familiar with the gc/gd era up till 2007. Maybe later models have something what would drop in.
  22. it's a bit misleading, they are and aren't depending on the years. 05+ sti's changed to 115x5 hubs and cartridge style bearings. They are no longer press in bearings. 08+ wrxs changed to cartridge like sti's. so, 04 sti, 07 and earlier wrx are exact same knuckle/hubs as base impreza. no differences there, only beefier axles or different brakes on the better models.
  23. Cut up a credit card, jam in between seal and snout, pry all you want with screwdriver.
