nvu
13
Everything posted by nvu
i have the 1000lb one, same design but 4 wheels instead of 3. works fine for my rebuild, 750lb should be fine also. use the short transmission bolts that came out of the bellhousing to mount the engine. i'd put large washers on the bellhousing face so the steel mount tubes don't dig into the aluminum
Eww.. sounds like the hub might've pulled out a bit. At this point I'd be cobbling together a long bolt and washers to squeeze the hub back in place. Or just pick up one of those oncar bearing kits. https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=on+car+bearing+kit&* Could also take the entire knuckle out, put a socket behind the inner race, and tap it back in with a hammer.
I had a similar problem when rebuilding a 2.5l turbo. No pressure after trying to crank for 3mins off and on. Took out the oil filter, cranked until oil flowed out of the filter area. Then put in the oil filter empty and cranked again, pressure came up almost immediately. Seems like having the oil filter filled and the pump dry would be enough to prevent the pump from priming properly. Hopefully this works out for you.
I've cobbled a jdm forester turbo 4.44 5mt into a USDM 03 wrx block before. Bolts right up, mine were female axle. Mine had dowel pins on the transmission and also on the engine block. Did some measurements and found it was simpler to tap out the ones on the jdm transmission and file the existing ones on the engine ever so slightly; probably not necessary. in retrospect, i should've just kept tapping in and out the dowel pin on the transmission side until the hole starts loosening up. you could probably skip all this and tighten the bolts for the last .25" if you're extra careful everything is lined up. speedo will read higher than normal but this was from a forester to an impreza.
Bad fuel pump
nvu replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Did the walbro 255 on mine, it's a longer pump than stock. I ended up using a pipe cutter and bubble flare tool to trim off about 1/4" on the assembly to make it fit. This is how it looked before trimming the pipe. -
I've changed the lower portion before without dropping the rack. I remember a really hard fitting to loosen/tighten because there's no access for an open end wrench. I think I eventually got to it with a crows foot and several wobble extensions... and tape to hold things in place. It's awkward, you'll have to feel your way from the blind side. Car was 03 impreza. If I had to do it again, it would've been easier to disconnect the steering column link and drop the rack a couple inches.
you'll likely have seized up turbo flange nuts considering how old the car is. they will round off if you're not careful. I usually use a propane torch directly to the nuts until they are slightly red. Then they'll break free with hand tools. inspect the oil inlet pipe on the turbo, they commonly to fail near the weld point after a while. you can bend it out of the way to remove the old turbo as long as you're doing it by hand and making a bend in the center of the pipe; don't use pliers. bend it back to exactly line up with the inlet hole afterwards. the oil outlet hose that connects to the bottom of the turbo should be soft and pliable. replace if it feels hard when squeezing with fingers. when installing the new turbo, as caboobaroo said, the inlet hose can rip if you're not careful. i loosen the bolt holding the intake pipe so it could slide forward a bit, then wiggle the turbo in. sometimes when working with a bigger turbo that can't be fit with wiggling alone, i loosen the uppipe brackets and remove the exhaust header. that leaves the uppipe dangling and enough clearance to wiggle the turbo onto the intake hose. look up how to prime the new turbo with oil before first start of the engine.
2002 wrx
nvu replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
It doesn't sound like your son changed the uppipe yet? it's not part of the catback exhaust. To reiterate what matt167 and wtdash said, please make sure the uppipe is changed to catless before changing to a catless downpipe. If this was done already, go ahead and change out the downpipe. -
black metal pipe stuck to the manifold? that's part of the pcv system. that back bolt is a pain. if you look from the top, the intake manifold splits into two runners leading down into the head. i've been able to find the right mix of socket and wobbler extensions to poke in between the two intake runners and bend downwards to reach that bolt.
roll pin can be tapped out from either direction. when you put on the new axle, get a bright flashlight and shine through the roll pin hole from behind. make sure you can see a perfectly circular hole before tapping the new pin back in. if not, pull out the cup and flip it 180deg and put it back in.
I've had good luck finding odd hose leaks by pressurizing the coolant system. Warm up the car, turn off engine, pull out the overflow hose from the tank and put about 10-15psi into it. Ive found failing hose clamps around the heater hoses and turbo reservoir this way. Was chasing the problem for months after the engine rebuild. Car doesn't overheat, no bubbles in system, it just starts losing coolant between fillups. For my case, coolant would sneak out the heater hose clamps on the firewall. Which was where I disconnected them when pulling out the engine.
swapped blowers on my 2003 impreza wagon with a 2006 year unit. it looked like the motor is molded into the ducting assembly. i could be wrong though, didn't look too carefully as i already had the entire assembly and didn't need to swap blowers. anyways, to get it off of the car, I had to remove the nut holding the white upper piece to the dash. (it's hidden under the wiring loom). then when all nuts are off, the white piece is held to the black piece via plastic tabs. you should be able to feel them and unclip them by hand. after that you should be able to pull the lower assembly out.
