nvu
14
Everything posted by nvu
No experience with automatics, I went from a cable throttle turbo to dbw turbo; same car, same manual trans. There's somewhat of a rev hang with the dbw when shifting gears. On the cable engine, you clutch in, let off gas, and shift. On the dbw, if you do the same thing, depending on how hard you're accelerating, the rpm would stay the same or even shoot up even though you released the gas. Not a big deal, you just learn to let off the gas before clutching in hard acceleration. I was annoyed for a month or so. With the manual I don't recall any twitchiness at the low end, but then again the rev hang bothered me more.
Some smoke in that rear area is okay, that's what the pcv is supposed to remove while idling. With the engine hot, rev it aggressively couple times, as long is it's not spewing out a constant trail from the oil filler it should be ok. Was the old one clogged? Shake it, there should be a loud and metallic clack like a paint spray can. A dull thud would mean it's starting to clog up. You'll still have to address that oil leak, take off the cam covers. They should be 10mm bolts. Being that old and oil soaked, expect some nuts to be seized and end up breaking the plastic they're molded into. If that happens, just proceed with the rest of the bolts and pry the cover off. Only the side covers are removable, the center one can't be removed without taking off belts and crank pulley. Flashlight and phone camera can be used to inspect the center area.
- 23 replies
- oil leak
- piston slap
(and 2 more)
Tagged with:
Maybe excessive blowby and/or clogged pcv? Drive around and get the car up to temp, take off the oil cap and rev the engine a bit. If you see smoke coming out of the oil filler neck it's blowby. It's rare to see the oil pump seal leak.
- 23 replies
- oil leak
- piston slap
(and 2 more)
Tagged with:
I've disassembled outer joints by holding the entire shaft vertical, outer joint pointing up. Smack it down on a wooden workbench where the cup catches the edge and the weight of the rest of the shaft pulls it out of the c clip. Even easier if you have a V corner workbench. Also... mind where your toes are.
Install Cam Seals
nvu replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Grease or oil up the inside where it meets the shaft. Lightly grease or oil the outside so it doesn't pinch while going in. I prefer pressing as hard as possible by hand until it's centered, tap until flush with the head. I had an older ej22 head with a chamfered hole on the driver side. In this case, using the old seal flipped around would allow me to push the new seal further in. Don't bottom it out, the goal is to push the seal in just enough so the outer area makes full contact in the metal hole and holds tight. Oh the snout with the oring, silicone grease or oil is ok. -
'00-'04 Roof
nvu replied to NV Zeno's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
https://parts.subaru.com/a/Subaru_2001_Legacy-Outback-Wagon-30L-AT-4WD/_51505_6029304/ROOF-RAIL-ROOF-SLATS/B12-922-02.html are these it? looks more than just glue. -
Get it fixed, the tires will wear unevenly. Also check if you have directional tires, not only is there an inside/outside to those, but also a directional rotation arrow. Those would come in sets with 2 left and right sides.
17" wheels???
nvu replied to trapper jim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
no, the stud pattern is 5 x 100mm if I recall. 4.5" would be 114mm -
Hi again, from my previous post, I have a 98 obs with a bad shortblock. The plan was to look around on car-part and visit the local yards for a complete EJ22 but so far that's been turning up empty. I do see a lot of EJ18 SOHC's around, that seems a little too small for an awd wagon. Still searching for the EJ22 in the meantime. Are there other engines that will work with the 98 OBS ECU? The other option is refreshing the heads and putting another shortblock on. I have one from an EJ257, the heads are the EJ22 with external headbolts, single port. Will this combo work with current ECU? This is a california car so the ecu needs to remain original for smog.
> Can it really just be unbolted with control arm left on car? It can, I'd remove the ball joint from the knuckle to relieve spring pressure. Then just the rear bushing can be undone and replaced by hand. Otherwise you might need to use a jack to push things back up to bolt them in. Loosen the big nut while it's in the car if you don't have an impact wrench. Ideally you want to tighten the big nut last while the car is sitting on the ground. I don't, it's been fine.
- 5 replies
- 1
- control arm
- bushing
(and 3 more)
Tagged with:
I've recently acquired a 98 impreza outback sport that had an oil leak. After tearing down the engine it looks like the block is unusable, no threads on one headbolt hole, cracked into water or oil area. Opposite head bolt snapped off, looks like they put some type of dry powder in it to stop leaks. One head has very discolored exhaust valves. It might be okay, but at this point I'm cutting my losses and looking to put in another engine. The original one looks like an EJ22 MAF version, no EGR. Heads are external headbolts, single port exhaust. Has the newer style tensioner on the block. There's a local place which stocks jdm EJ20 sohc engines and I'm wondering if these would work. They all seem to be the internal headbolts heads. Will these newer ones work?
I use roll pin method on my impreza and can wedge out the axle without needing to take apart any suspension components. Pretty sure that wouldn't be possible with the stub method. Also you won't spill gear oil all over if you leave the stubs in. Pins are easy to get to on the impreza, not sure how much access there is under a legacy though.
Those pics look like a throttle position sensor (TPS).
- 43 replies
- MAF Sensor
- 2003 Subaru Impreza 2.5 RS
(and 1 more)
Tagged with:
not sure on newer forester's but when i had to replace the line on my 03 impreza i used some crow's foot sockets and wobble extensions to reach the nuts on the rack side. there's no direct line of sight to the area so i used a cellphone to look at the area and placed everything in by feel. for the impreza, the line that goes into the rack was below the car and ran along the crossmember before threading into the steering rack.
https://www.google.com/search?q=ball+joint+separator&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiNj7rsx6DXAhVK52MKHaEHA34Q_AUIDCgD&biw=1497&bih=859 https://www.google.com/search?biw=1497&bih=859&tbm=isch&sa=1&ei=L2r7WcjbGImqjwPfrL6oBw&q=bearing+puller&oq=bearing+puller&gs_l=psy-ab.3..0l10.13466.15415.0.15607.14.14.0.0.0.0.146.1260.8j5.13.0....0...1.1.64.psy-ab..1.13.1257...0i67k1.0.-PS4kQ6p5Zg#imgrc=A96GtQP9J0Gg1M: maybe something like these would help
