swapped blowers on my 2003 impreza wagon with a 2006 year unit. it looked like the motor is molded into the ducting assembly. i could be wrong though, didn't look too carefully as i already had the entire assembly and didn't need to swap blowers.
anyways, to get it off of the car, I had to remove the nut holding the white upper piece to the dash. (it's hidden under the wiring loom). then when all nuts are off, the white piece is held to the black piece via plastic tabs. you should be able to feel them and unclip them by hand. after that you should be able to pull the lower assembly out.
