Everything posted by nvu
After brake job, electronic parking brake set, idiot lights ALL lit up, car immobile
nvu replied to craigmcd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know for sure but suspect eyesight equipped vehicles need this step. I heard it's a nightmare to replace windshield glass with an eyesight system and it needs some special alignment and setup again. Not something any windshield shop can do.
nvu replied to craigmcd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI vaguely remember a youtube video about having to hook a computer up to the car and set something before installing the brakes. I'll see if I can find it again...
2006 Forester Power Steering Pump noise when cold?
nvu replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry steering with the fill cap off and see if tiny bubbles apear. If so, likely the S shaped hose from the reservoir to the pump has gone brittle and sucking in air at the pump nipple.
Daytime running lights
nvu replied to Wtwills's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's a module you unplug to turn off the DRL permanently. On an 02 impreza it's passenger side glovebox/footwell area near the fuel pump relay. It's probably the same area on your legacy. Download the service manual for your car and find out.
a/c pressure switch
as a test you can just skip it all together and short the connector pins together. the compressor should kick on. its function is pretty basic, too high or too low pressure it'll switch off. it'll short the pins when the pressure is nominal.
2014 Impreza start up noise
nvu replied to Bilegeyser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit's likely fine, the timing chain tensioner can get sticky, but doesn't fail catastrophically like the timing belt tensioners. those years had the oil consumption issues due to low tension rings from the factory. probably check if your model year is affected and keep an eye on oil levels between changes
nvu replied to Bilegeyser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoil filter up top is an fb engine, timing chain. they're noisy on startup until the tensioner fills with oil. no need to replace if it doesnt sound bad when warmed up
2001 Forester - Coolant boiling
nvu replied to kruteck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck if the cabin heater working. If so the pump is working. Might still be some air trapped in it, try parking at the steepest incline you can and do the radiator fill again.
- found something that doesn't look factory need help identifying
Help! Front end is 2" too high after rebuild
nvu replied to 5000fingers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe suspension gains positive camber really quickly when it's near the end of its travel. Not sure what's causing your too high issue, but the vibrations are likely from the tires gaining positive camber when the suspension bounces up higher than usual.
Oil Pressure Sensor Switch - Should it sit flush?? 2010 Forester
nvu replied to xocomil21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs long as it doesn't leak it's fine. They are tapered threads so likely the new one has more meat on it and sits higher. Is the 2010 an EJ engine? If so don't worry about cracking the block. The oil galley has a nut with a tapered hole for the sensor. Worst case you only need to replace that nut if the sensor threads get ruined. Random picture, but you see the nut where the pressure switch goes on to.
brake light and battery light coming on and off together randomly
nvu replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLikely as a failsafe. If the charge bulb burns out, the alternator would stop charging and there wouldn't be any other way to know until the battery's drained.
nvu replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe brake indicator is also connected to the alternator. If it's going off and you're sure it's not the fluid/parking switches, the alternator is grounding itself. Either it's bad or there's a short somewhere.
no start weirdness a month after front end impact
nvu replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust occurred to me there's an intake air temp sensor on the maf. The codes are pointing at the maf, did they clear after you plugged it abck in and reset the ecu? On my 2003 impreza, I've had the maf heater wire cook itself brittle before. Cut open the wiring loom and see if any individual wires have discolored. With my case, the car never threw any codes, but the plastic tab was broken off for a while. Only found it after splicing in a new pigtail, the burnt area was about 6" before where there was a cable tie on the loom.
EJ22 30 PSI on all four cylinders HELP
nvu replied to Bobthecat01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCollapsed hydraulic lifters maybe?
nvu replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou mentioned a lot of things got crushed in the airbox area, check the plastic piping from maf to throttle body for cracks, etc... check for vacuum leaks too. Did your year come with plastic intake manifolds? That might be suspect too.
nvu replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes it start without the maf connected? Try disconnecting battery to clear all maf learning, unplug the maf and keep it disconnected, plug back in the battery and start it. At very least it should start the engine in failsafe limp mode. If it starts again, the problem is likely sensors. If it's not starting then, it's more basic mechanical: fuel, spark, timing...
"Broken" pitch stop mount
nvu replied to Raynman1989's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen the tail end of the transmission jumps up and down, it tilts the engine back and forth. If your rear transmission mount is the oem open style, change it to the solid group n style. If the prev owner already installed it, the pitch stop is sort of redundant. These are probably not the exact ones for your car, they're even different. but you get the idea, look at the rear trans mount and see if they're already solid.
HELP! 1, 3 & 4 Zero Compression 96 Imprezza EJ22
nvu replied to JesusLady's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood point el_freddo, the results won't be accurate. My reasoning would be to rule out any seriously broken parts. With only the compression tester in one hole and the no spark plug in the others. The main idea is to verify each cylinder still has any compression. If one cylinder has bent valves or something broken, the starter wouldn't have much resistance and spin freely. If there's really a 0psi at this point, something is majorly bent, not tightened down, or broken.
nvu replied to JesusLady's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXZero psi anywhere sounds bad. You need to test and make sure you have compression at all cyls. The belt has to come off again. Turn each camshaft by hand until they're unloaded so the valves are closed. With the spark plugs out, turn the crankshaft by hand to confirm it's not catching on anything. If all is well, test the compression without the timing belt installed and confirm you're getting pressure.
EJ22 identification help
nvu replied to CompanyMan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are two outbacks in that era. The legacy outback, which is the bigger 4 door legacy wagon. Impreza outback sport, the smaller impreza wagon.
2002 Subaru Impreza TS - AC Compressor 2002-2003 Only?
nvu replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2003-07 impreza should be a safe bet, but other models are the same in the era should work too. It's been a while, I forgot which year compressor I swapped in to replace the 2002 impreza wrx. The electrical connector was different. My 03 had a 1 pin connector. It's 12v to activate the clutch. Cut the connector from the old clutch and put it on the newer unit. Been working fine since 2015
93 Legacy throttle issues
nvu replied to Bobs93Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure, I guess it means chassis ground.
nvu replied to Bobs93Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got the manual from here, it's the 1992 one. https://sl-i.net/FORUM/showthread.php?18087-Subaru-Factory-Service-Manuals-(FSM)-Every-Model-USDM-EU
2002 Impreza Ac Compressor Low pressure return line Frost coated?
nvu replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow was the state of old compressor, did it frag and sent metal down the line? If you still have it around, try dumping out all the old oil. If it's close to black, chances are it's been grinding away and the iron particles have oxidized. If there's moisture and gunk in the oil, it gets extremely thicker when it starts to freeze. It'll coat the walls of the evaporator and not transfer heat from the cabin. The refrigerant stays liquid until it reaches the outside line in the engine bay, then it can finally flash off and that's why frost builds up.
