nvu
    13
Everything posted by nvu
  1. You might be in luck, the clog is at or near the nozzle then. Unplug the coupler again to prevent pressure from blowing out any couplers in the cabin. Clear out the clog on the nozzle by backflushing it with pressure air or water.
  2. Also in case you're not aware, it's an AWD car. It needs to be towed on a flatbed if the engine doesn't work. Don't let them tow if it's the type with two wheels in the air and 2 on the ground.
  3. Was rubber hose and couplers for my 98 impreza, no hard lines. It ran across the roof to the wagon hatch for mine. Had to take all the trim out to reach every part because genius me thought putting an air hose to one end and blowing it would solve the blockage; only popped out a coupler. Might as well start chasing the line and taking off trim as you go, sounds like a coupler popped off for yours too. It's not hard, just time consuming. Start from rear to front.
  4. It's not a freeflowing design, but you can take off the farthest injector to flush it. Use carb cleaner to let it dissolve. At this point just assume your injectors are clogged and look into backflushing them. There are lots of videos on how to do this.
  5. Could be normal with a loose belt or tensioner. Either way, if it's off by one tooth won't cause misfires you're seeing. Get a marker and count the teeth, if it all matches the belt is set correctly.
  6. All 5mt use the same linkage design and can be interchanged. Newer ones are riveted instead of bolt and nut for the transmission end. The 97 will work.
  7. For the slightly shorter block and needing to open up the holes on the intake, I've ran into this before with using an ej257 block on an ej22 intake. The slight shortening causes more slack on the passenger side cam. This was sohc and the timing was maybe just under 1/2 tooth off, everything worked ok. Maybe for dohc the differences matter more with 4 cams in the mix. There are adjustable eccentric idlers that can correct for this, but I don't know who makes them anymore. Last set I used was maybe 2015 from lic motorsports to correct an ej257 with overmachined ej255 heads. They're no longer around.
  8. If it's not throwing cel's, there's not much more info you can get from romraider that you can't get from a live data odb2 reader. It's usually the long and short term fuel trims you'll need to look at. They shouldn't be unusually high after the car has warmed up.
  9. Quick check on romraider doesn't have your 03 NA ecu listed. Either doesn't have a definition or the ecu is unsupported. https://www.romraider.com/forum/viewtopic.php?f=35&t=7591
  10. you cannot bake them with electrolytic capacitors installed. theyll get ruined before the solder reflows. you have to remove all of them prior. ive done video cards and made custom reflow kits. theyre not car ecus but same idea applies. heres a general idea on how it works https://www.google.com/search?q=reflow+car+ecu
  11. It never was backfire. It's afterfire, there are youtube videos explaining it. The noise comes when you let off the gas and it's over rich. It seems to happen around 3k for your car. I wouldn't worry about it, it's common on all older cars. The soot issue sounds like something better to chase since it's a california car. Basic maintenance, plugs, oil, o2 sensors. Also 2012 probably falls into the weak piston rings recall, has the car been consuming oil? Going back to what other shops said, what tests have they done to confirm this. Backpressure, did they drill a hole before cat and measure? Valve timing, take off timing covers and match timing marks.
  12. Also you mentioned you pulled the engine to do the headwork. When you put everything back, those big super junction connectors, take them off and inspect every pin on both ends. Make sure none are bent/broken. Other things to check: grounds, rule out a bad ground, run a thick copper wire from the battery negative post to any bolt top center of the engine block. the fuel lines aren't installed reverse coil wires, pull out the boots and look at the connectors, do they clamp the plugs tightly. check with a used plug laying around Have you tried starting the car with a freshly charged battery, or jumper cabled to another running car?
  13. You have compression, it's not likely timing belt issue. Spark and fuel are there. Next thing to check are your cam and crank sensors. Check all hoses on intake are plugged in. On older engines, unplugging the maf will force the ecu to limp mode. It should fire up even with no intake installed. Not sure if newer cars still do this.
  14. Also unhook both endlinks and shake the swaybar. If the sway bushings are worn they'll drop and rattle. Just replace the endlinks now, you can do it with the car on the ground and some box wrenches. The rear control arm bushing could leak, but they rarely go bad. The smaller front one goes bad long before the rear one does. Pry on it with a screwdriver, if you can move it easily with a hand screwdriver it's bad.
  15. I'd probably remove the header from the car and sand the flanges. It's likely they're no longer flat, light sanding with a flat block will show. I've used a belt sander to get terrible ones sealing again. Yeah the aluminum strips easily on these cars. I've had studs strip the threads from just removing them. All that heat cycling and corrosion. I've used mapp gas to preheat the area then blast the nut until dull red to get out the stubborn ones. As mentioned above, end of the day it's either easy or terrible depending on how well the fasteners come off.
  16. That coating looks flaked off everywhere, likely the same on the other side. It should've been an all metal gasket. Chances are high the heads are warped. Check head flatness as stated above and consider sending them for resurface. MLS gaskets aren't forgiving as composite if there's even a bit of warpage.
  17. Did you switch to all metal gaskets when you rebuilt it? If you were still using aftermarket composite gaskets, they were a flawed design on the ej25's and would leak eventually.
  18. If it's constantly bubbling from the reservoir, that's a sign of headgasket failure. Exspecially if it does this while idling.
  19. sounds like misfire/afterfire. it's okay if it only does this unloaded and clutch in. when you press the accelerator past a certain point, the ecu goes into open loop mode. it fires whatever rich amount of fuel and doesn't rely on any sensor feedback. the overrich mix doesn't completely burn in the cylinder and could ignite after exhaust port. this doesn't happen if the engine is loaded down and in gear as it can't freewheel and spit the excess fuel out the exhaust port. don't worry about it unless it's actually misfiring when the engine is loaded, you'd see the check engine light blinking.
  20. Those brass flakes reminds me of oldschool bars stop leak powder.
  21. the intake holes were slightly narrower when i put together my ej22 with ej257 block. drilling the intake holes slightly larger got it to fit.
  22. I don't. Turbos have all metal headgaskets and stopleak won't help sealing a leak there. The subaru recommendation for conditioner was for NA cars that came with composite headgaskets.
  23. Switch to screw clamps while you're at it. Silicone hoses will need more clamping pressure to seal. I prefer the wire style clamps on older subaru's vs the band clamps found in auto stores. They don't bite into the hose as much.
