Whatever
About Whatever
- Birthday 01/17/1998
Gender
Male
Location
Bellevue, WA, USA
Referral
Searched for some wiring stuff, suspension and engine and this site is always helpful to me.
Biography
I love panda express and lowered cars.
Vehicles
84 gl hardtop ea81, 92 Honda accord.
Whatever's Achievements
Member (2/11)
4
I tried picking that transmission up the other day and it turns out since I'm 17 they won't let me in the yard. I've been looking around for a fwd impreza transmission but still no luck.
- 9 replies
- engine
- transmission
(and 3 more)
Tagged with:
Sweet I'm heading up tomorrow the old ones out.
- 9 replies
- engine
- transmission
(and 3 more)
Tagged with:
Cool thanks!
- 9 replies
- engine
- transmission
(and 3 more)
Tagged with:
I picked up an ej22 for $125 and I'm pretty set on it. Got a timing belt kit on it rear seal and it has new head gaskets. I will start looking for a fwd impreza transmission. Pulled a fuel pump off a loyale. Got the intake with a maf. "Front ea crossmember drill/grinder to fit with any ej centerpiece with flat bar at the rear. Works" Ok. So will the ea81 axles fit in the fwd ej22 transmission (off an early impreza)?
- 9 replies
- engine
- transmission
(and 3 more)
Tagged with:
I have a 5 speed manual front wheel drive ea81 that I am wanting to fit an ej22 into. Here are the options I am looking at: FWD Impreza transmission: I read that the impreza ej22 fwd transmissions are 23 spline and so are the hubs of the ea81 cars. I also read that to use an ej22 transmission, I could use the front and rear crossmember pieces out of an xt6 and the center one out of a wrx. If so, are they a direct bolt in? And what year wrx would I be looking at? And is all of this possible? Is there any way I could fabricate some sort of crossmember or modify the original one to fit an ej transmission with just a drill and an angle grinder? Reusing my stock transmission: With these parts, would they mate up together? -ea81 clutch -Flywheel redrilled to the ej pattern -xt6 pressure plate. (I don't know if I have to get another throwout bearing or if I can reuse the one that's in there). -Adapter plate since the shaft of the ea transmission is longer than the ej transmission. Ea82 transmission: Readily available and really cheap. From what I understand they are pretty similar to the ea81 transmissions too, and I can pick one up with significantly lower miles than my current one for pretty cheap so I'd be willing to do it if it's not too complicated. The thing is that my stock transmission has 250000 miles on it, so I was planning on replacing it anyways and I'd have to pay $400 for a redrilled flywheel and adapter plate from sjr since I don't have any good machining tools. I was thinking that for that price I could just get a fwd ej transmission, am I right?
- 9 replies
- engine
- transmission
(and 3 more)
Tagged with:
Turn signals not working, replaced flasher relay.
Whatever replied to Whatever's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's a 1984. The plastic shroud is already removed. I haven't checked my fuses yet, that was stupid of me.- 3 replies
- flasher relay
- turn signal
(and 1 more)
Tagged with:
I finally got my car running, and took it for a drive. Here's what my problem is: * My car idles really low, and it will die unless I give it gas. * Sometimes, when I press the gas pedal, it will stick. * It backfires at higher rpms when I'm cruising. * The ECS light is on. I've replaced the spark plug wires and both the main and secondary fuel filters. What should I check next?
- 2 replies
- rough idle
- low idle
(and 2 more)
Tagged with:
So my turn signals aren't working. They don't even click. I tried replacing the 3 prong flasher relay, but they still don't work. The turn signal switch is kind of hanging down from the steering column. Any suggestions? Which wires should I be looking at?
- 3 replies
- flasher relay
- turn signal
(and 1 more)
Tagged with:
Followed trevors advice. Learned about how the suspension works and figured out how to lower the back. On either side there's 12mm bolts. They hold the trailing arms and the torsion bars to The frame. There are two torsion bars and a tube that goes around them (I mistook the tube for the torsion bar). Theres this thing splined on both sides inside in the middle of the metal tube that the torsion bars slide into. Anyways I took out those 12mms and three 17mms on either side that held the trailing arms to the lcas, and I pulled the whole torsion bar assemblies on either side out of the tube and notched them towards the sky. It lowered my car a few inches so its super flush now. Now I just gotta get some fatter tires.
- 12 replies
- 1
- ride height
- springs
(and 7 more)
Tagged with:
My car doesn't have the adjusting bolt on the torsion bar.
- 12 replies
- ride height
- springs
(and 7 more)
Tagged with:
And if I were to go the xt6 route, how would I run the brake lines from the new rear caliper? And should I get parts off a fwd or awd xt6 or are they the same?
I don't have a lot of tools. I was considering a 6 lug swap though. Should I attempt it with a regular drill rather than a drill press? I could use a 6 lug wheel as a template and they're pretty cheap on craigslist.
Thanks everyone. And I do have that awkward positive camber in the front.
- 12 replies
- ride height
- springs
(and 7 more)
Tagged with:
clutch cable replacement
Whatever replied to oldgoatdude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There's a clevis pin that goes through the pedal and the end of the cable. The pin won't come out without sliding the pedal away from the pedal shaft. There is a locking ring on the end of the shaft that you need to pry off with some decent pliers to slide the pedal. The locking ring on the end of the pedal shaft looks like a washer, but it's not. This is for an ea81 by the way.
