Gopherbroke
  • Location
    Winchester il
  • Referral
    Todd peters
  • Biography
    I have always loved these cars
  • Vehicles
    1979 Subaru GF
Recent Profile Visitors
538 profile views
Gopherbroke's Achievements
Advanced Member
Advanced Member (3/11)
6
  1. thank you very much i didnt know what to put it in so i had that cardboard tube, it fit
  2. It's Nolan Phone is small and I get in a hurry Ya I'm thinking the FF1 book ur talking about , I have it As soon as I get trailer cleaned out I'll mail it to you.
  3. I've got a lot of parts but don't know what they are, since I didn't get the 77-79 book, when I bought the parts. I need a book if anyone has one to sell or loan. I can take it to quick print, copy it and send it back!! Thanks molan
  4. 1974 coupe 1976 gf 1976 Sw 4wd No pic 1977 Sw 1979 gf 1979 FE
  5. list 3 FF-1 683200050 turn signal unit $25 qty 1 811688600 oil pan drain gasket $2 qty 10 644003034 exhaust gasket $5 qty 12 6232040001 washer-axle assy F $2 qty 4 625006000 front shoe hold down $1 qty 10 621005260 RH rear suspension bracket $20 qty 1 662100071 FLH door regulator $50 qty 1 662100061 FRH door regulator $50 qty 1 661310370 FLH door lock $20 qty 1 661221190 LH-LWR door hinge $20 qty 2 661310380 door lock R-door-RH $20 qty 1 662100081 R door RH regulator $50 qty 1 657704000 FRH bumper stay $10 qty 1 625301220 front brake shoe $10 qty 5 891464111 points $5 qty 103 641002060 engine stop mounting cushion $5 qty 5 661101001 glass channel F door $1 qty 1 621414060 plate front suspension $1 qty 3 641003232 bracket -stopper engine mounting $5 qty 4 657013012/657213011 F hood stay $15 qty 9 684111062 Rim LH $25 qty 1 812606110 valve cover gasket $5 qty 20 625100014 FLH back plate $10 qty 2 812606110 generator bracket $10 qty 2 684114131 rear light base LH $20 qty 1 631900062/631900061 steering column $10 qty 5 621003082 front shock $5 qty 1 621003044 shock $5 qty 1 661103030 clip $1 qty 4 683506020 noise condenser-dash $5 qty 3 662100101 2dr RH window regulator $50 qty 1 62105260 trailing arm bracket LH $20 qty 1 62105270 trailing arm bracket RH $20 qty 1 684101402 rear lens LH $50 qty 3 625200031 wheel cylinder F-RH $10 qty 2 644013011 insulator exhaust $5 qty 2 625302020 parking brake RH lever $5 qty 2 625302030 parking brake LH lever $5 qty 1 sheet metal 650002680 1975-76 under cover LH $10 qty 2 door 662310220 1972 F door sash R RH $20 qty 1 662310200 1972-73 F door sash F RH $20 qty 1 engine 6450001190 1972-73 radiator hose $5 qty 1 6450001191 1973-74 radiator hose $5 qty1 329882810 1975 coil $10 qty 1 382590102 1972-75 gasket cylinder liner $5 qty 4 394850611 1972-73 solenoid valve body $15 qty 1 813738610 1972-74 flywheel lock washer $1 qty 4 822118600 1972-74 intake gasket $5 qty 1 319995100 1975 valve rocker assy $20 qty 1 412307111 1975 head gasket $5 qty 1 391464312 1976 points $5 qty 68 891464111/891464821 1972-75 points $5 103 641002320 1972-74 engine motor mount $10 qty 1 644015074 1972-74 tail pipe cushion $5 qty 2 645010470 1975-76 radiator $100 qty 3 front suspension 621008040 1972-73 front coil spring $20 qty 1 621052050 1972-74 front strut $20 qty 1 brake 625210041 1972-73 wheel cylinder repair kit $5 qty 2 625026030 1972-73 coupe brake boot $5 qty 6 625006000 1972-73 front shoe hold down $1 qty 10 623227040 1972-73 nut axle $5 qty 2 6250002090 1972-74 coupe F disc brake stopper plug $5 qty 1 625304010 1975 retainer $1 qty 8 625008140 1975 auto adjuster lever $5 qty 2 625301281 1975 brake shoe $10 qty 5 625025020 1972-75 brake piston seal $5 qty 4 625009030 1972-73 brake bleeder caps $2 qty 2 623228051 1972 brake lock plate $2 qty 4 625301281 1972-75 brake shoe S,LH $5 qty 3 623501050 1972-76 brake housing LH $5 qty 11 dash 682185061 1972-73 coupe rear defogger switch $20 qty 1 674022140 1973 hose (cock) $5 qty 1 lens 684153160 1972-73 coupe backup light rim assy $25 qty 1 684173130 1972-73 license lamp len $20 qty 1 684143260 1972-73 coupe license light body $10 qty 1 transmission 682160041 1972-73 neutral switch $15 qty 3 812198608 1972-75 shim drive pinion 0.175mm $1 qty 4 637118000 1972-75 clutch cable nut $1 qty 6 440377000 1975-76 oil pan AT $10 qty 1 451610100 1975 AT seal $5 qty 4 806712050 1975-76 AT seal $5 qty 2 464610100 1975 AT seal $5 qty 1 682160050 1975 neutral switch $10 qty 2 wheels 623027001 1975 hubcap(500) $5 qty 4 chrome 692011481 1972-73 RH grille (plastic trim behind window) $50 qty 1 692011491 1972-73 LH grille (plastic trim behind window) $50 qty 1 wiper 686121000 1972-76 wiper sleeve unit B $5 qty 13 686112120 1972-74 wiper link system $20 qty 1 differential 622004020 1975-76 diff mount bushing $5 qty22 trunk/rear hatch 661334081 1975-76 SW rear latch $20 qty 2 661007160 1975-76 SW spacer rear hatch out $1 qty 4 690323050 1974-75 trunk board center $10 qty 2 steering 631504001 1972-75 tie rod dust seal $2 qty10 631306030 1972-74 pipe gear box air vent $5 qty 1
