Gopherbroke
Everything posted by Gopherbroke
The 76 Sw came from montana
list 3 FF-1 683200050 turn signal unit $25 qty 1 811688600 oil pan drain gasket $2 qty 10 644003034 exhaust gasket $5 qty 12 6232040001 washer-axle assy F $2 qty 4 625006000 front shoe hold down $1 qty 10 621005260 RH rear suspension bracket $20 qty 1 662100071 FLH door regulator $50 qty 1 662100061 FRH door regulator $50 qty 1 661310370 FLH door lock $20 qty 1 661221190 LH-LWR door hinge $20 qty 2 661310380 door lock R-door-RH $20 qty 1 662100081 R door RH regulator $50 qty 1 657704000 FRH bumper stay $10 qty 1 625301220 front brake shoe $10 qty 5 891464111 points $5 qty 103 641002060 engine stop mounting cushion $5 qty 5 661101001 glass channel F door $1 qty 1 621414060 plate front suspension $1 qty 3 641003232 bracket -stopper engine mounting $5 qty 4 657013012/657213011 F hood stay $15 qty 9 684111062 Rim LH $25 qty 1 812606110 valve cover gasket $5 qty 20 625100014 FLH back plate $10 qty 2 812606110 generator bracket $10 qty 2 684114131 rear light base LH $20 qty 1 631900062/631900061 steering column $10 qty 5 621003082 front shock $5 qty 1 621003044 shock $5 qty 1 661103030 clip $1 qty 4 683506020 noise condenser-dash $5 qty 3 662100101 2dr RH window regulator $50 qty 1 62105260 trailing arm bracket LH $20 qty 1 62105270 trailing arm bracket RH $20 qty 1 684101402 rear lens LH $50 qty 3 625200031 wheel cylinder F-RH $10 qty 2 644013011 insulator exhaust $5 qty 2 625302020 parking brake RH lever $5 qty 2 625302030 parking brake LH lever $5 qty 1 sheet metal 650002680 1975-76 under cover LH $10 qty 2 door 662310220 1972 F door sash R RH $20 qty 1 662310200 1972-73 F door sash F RH $20 qty 1 engine 6450001190 1972-73 radiator hose $5 qty 1 6450001191 1973-74 radiator hose $5 qty1 329882810 1975 coil $10 qty 1 382590102 1972-75 gasket cylinder liner $5 qty 4 394850611 1972-73 solenoid valve body $15 qty 1 813738610 1972-74 flywheel lock washer $1 qty 4 822118600 1972-74 intake gasket $5 qty 1 319995100 1975 valve rocker assy $20 qty 1 412307111 1975 head gasket $5 qty 1 391464312 1976 points $5 qty 68 891464111/891464821 1972-75 points $5 103 641002320 1972-74 engine motor mount $10 qty 1 644015074 1972-74 tail pipe cushion $5 qty 2 645010470 1975-76 radiator $100 qty 3 front suspension 621008040 1972-73 front coil spring $20 qty 1 621052050 1972-74 front strut $20 qty 1 brake 625210041 1972-73 wheel cylinder repair kit $5 qty 2 625026030 1972-73 coupe brake boot $5 qty 6 625006000 1972-73 front shoe hold down $1 qty 10 623227040 1972-73 nut axle $5 qty 2 6250002090 1972-74 coupe F disc brake stopper plug $5 qty 1 625304010 1975 retainer $1 qty 8 625008140 1975 auto adjuster lever $5 qty 2 625301281 1975 brake shoe $10 qty 5 625025020 1972-75 brake piston seal $5 qty 4 625009030 1972-73 brake bleeder caps $2 qty 2 623228051 1972 brake lock plate $2 qty 4 625301281 1972-75 brake shoe S,LH $5 qty 3 623501050 1972-76 brake housing LH $5 qty 11 dash 682185061 1972-73 coupe rear defogger switch $20 qty 1 674022140 1973 hose (cock) $5 qty 1 lens 684153160 1972-73 coupe backup light rim assy $25 qty 1 684173130 1972-73 license lamp len $20 qty 1 684143260 1972-73 coupe license light body $10 qty 1 transmission 682160041 1972-73 neutral switch $15 qty 3 812198608 1972-75 shim drive pinion 0.175mm $1 qty 4 637118000 1972-75 clutch cable nut $1 qty 6 440377000 1975-76 oil pan AT $10 qty 1 451610100 1975 AT seal $5 qty 4 806712050 1975-76 AT seal $5 qty 2 464610100 1975 AT seal $5 qty 1 682160050 1975 neutral switch $10 qty 2 wheels 623027001 1975 hubcap(500) $5 qty 4 chrome 692011481 1972-73 RH grille (plastic trim behind window) $50 qty 1 692011491 1972-73 LH grille (plastic trim behind window) $50 qty 1 wiper 686121000 1972-76 wiper sleeve unit B $5 qty 13 686112120 1972-74 wiper link system $20 qty 1 differential 622004020 1975-76 diff mount bushing $5 qty22 trunk/rear hatch 661334081 1975-76 SW rear latch $20 qty 2 661007160 1975-76 SW spacer rear hatch out $1 qty 4 690323050 1974-75 trunk board center $10 qty 2 steering 631504001 1972-75 tie rod dust seal $2 qty10 631306030 1972-74 pipe gear box air vent $5 qty 1
help on part number 651631150
Gopherbroke replied to Gopherbroke's topic in Historic Subaru Forum: 50's thru 70's
ok thanks -
sorry was using phone to send pics -
Pics -
Pics -
Pics -
i believe its for brat tailgates ,just dont know year any help would be great thanks
list #2 FF-1 684101392 lens RH $50 qty 2 666004351 glove box door $25 qty 2 sheet metal 651871132 1976 HT rear 1/4 panel $175 qty 13 657240170 qty 1 651300801 1972-73 front right wheel apron $50 qty 1 door assy. 662234190 1972-74 coupe left 1/4 glass $50 qty 2 engine 382590102 1972-74 gasket cylinder liner $5 qty1 310300501 1975 crankshaft $25 qty 5 EA-62 new short block w/studs $100 qty 2 380040120/EA-63 new short block w/studs $100 qty 1 880038600 piston ring set 1300cc $10 qty 1 817534100 1972-73 thermostat 1100cc $5 qty 2 front suspenion 621008080 1972-73 SW front coil spring $20 qty 1 brakes 625013070 1972-73 coupe LH disc brake cover $10 qty 1 625100381 1972-74 SW,2dr,4dr RH back plate $10 qty 2 lens 684173440 1975 RH amber turn lens $15 qty 4 684143460 1975 RH body assy. $15 qty 2 684173430 1975 front turn round amber $10 qty 2 684151010 1972-73 FR amber $25 qty 1 transmission 842084100 1972-73 plug $5 qty 7 wheels 623005360 1972-73 hub cap (503) $5 qty 23 623005500 1974 hub cap (505) $5 qty 6 interior 693072981 1976 driver door card-blue $100 qty 1 693073260 1976 SW pass rear door card brown w/red carpet $100 qty 2 steering 380634800 pinion crown gear set $50 qty 17 631308010 1972-74 snap ring (boot)$5 qty 2 list #2
