Gopherbroke
Everything posted by Gopherbroke
  1. Looked for a long time to find this car. Took a lot of talking and money,but I got it Thanks to Todd in Texas. Only comes out of shop on very nice days. The interior is mint, except dash, of course. Under just as nice. Thanks everyone!!!!
  2. email address nolanshireman@yahoo.com this is pay pal address will try to get things out asap but home only once a week thanks
  3. yes will be shipping paypal and will try to package together to try to keep shipping down what is up is List 1 will be adding more later as going through it all but will be some time before all is done please send headings (interior,engine) then part numbers,and item thanks
  4. please send headings part numbers and item name i will try to get them out asap only home once a week thanks
  5. got alot of parts this is LIST # 1 sheet metal 651171372 1976 right 1/4 panel coupe 2dr $175 qty-40 657210761 1976 hood $100 qty-16 699901280 1972-76 right fender $150 qty-120 699901290 1972-76 left fender $150 qty-70 652412131 1975-76 rear skirt $75 qty-1 661250380 1972-74 SW panel assy.(back dr,lwr) $75 qty-6 661194150 1970-72 sw back door panel assy (lwr) $75 qty-1 661250330 1972-73 sw back door panel assy upper $75 qty-3 651631150 1978-81 Brat tail gates $200 qty 5 FF-1 parts 645032004 blower motor w/fan $50 qty-1 661221180 right lower door hinge $20 qty-2 625200001 front right/left wheel cylinders $10 qty-3 8920061102 starter armature $15 qty-3 822054100 carb gasket $5 qty-6 684146010 tail light dividers $5 qty-2 841418910 main transmission shaft $20 qty-1 842014124 shifting fork 15.8 marked 4 $15 qty-1 661310202 door lock assy back door lwr-rh $15 qty-6 686521004 fuel gauge-dash $25 qty-1 662100111 window regulator assy LH $50 qty-1 662100101 window regulator assy RH $50 qty-1 661162000 wedge door lock assy $5 qty-6 684101340 clear lens back up light $25 qty-7 684101402 rear lens left hand $50 qty-5 661101001 glass channel front door $10 qty-1 682116032 cancel cam (682116031) $10 qty-5 657793041 chrome bumper sd-rh $25 qty-8 662216091 lock complete sedan window (662216041) $25 qty-4 692035110 chrome grill molding B $20 qty-2 657213012 stay assy hood (657213011) $25 qty-4 623800040 front bumper drum aluminum $25 qty-1 637116000 boot accelerator cable $10 qty-5 651696050 ignition switch cylinder and key $25 qty-2 114541091 bolt wire stop $5 qty-6 666001102 glove box cardboard pocket (666001101) $50 qty-1 Door assy 662231140 1975-76 4dr,sw holder (f.doorglassRH) $15 qty-3 662231300 1975-76 HT holder (doorglass RH) $15 qty-1 662231220 1975-76 coupe holder (doorglass RH) $15 qty-1 662231130 1975-76 2dr holder (doorglass LH) $15 qty-5 662231160 1972-74 4dr,sw holder (doorglass rear RH) $15 qty-1 engine parts/compartment 641010210 1974 gl cross member $15 qty-2 316206200 1975 sw idler pulley $15 qty-9 391600601 1972-74 vacuum controller assy $15 qty-1 316076200 1975 sw fan spacer $5 qty-1 380050101 1973-74-75 piston OS 0.25 $10 qty-3 394872901 1974 choke camber $15 qty-1 892208612/892208602 1972-74 field coil $15 qty-6 895006111 1972-74 alternator pulley $10 qty-2 320504600 1975 air injection valve $10 qty-2 320664600 1975 anti a/f burn valve $10 qty-4 rear suspension 621110180 1975 dl wagon trailing arm RH $25 qty-4 front suspension 621047260 1975-76 stabilizer brackett $5 qty-1 brake 627003360 1974 sw brake line 2wd $10 qty-2 62510038 1975 front right back plate $10 qty-1 dash parts 686516121 1972-73 printed wiring plate $25 qty-1 686516231 1974 printed wiring plate $25 qty-1 686502100 1972-73 speedometer cable 4 speed $25 qty-2 plastic lens 684173410 1975 right rear len HT,coupe,2dr 4dr $50 qty-1 684173410RH rear lens $50 qty-1 684173420 1974 LH rear lens $50 qty-2 684173070 1972-73 LH rear lens $50 qty-1 684173430 1974 front turn signal lens $10 qty-20 transmission parts 340193600 1975-76 auto plantary input gear $20 qty-1 060162094 1975-76 auto trans ball bearing 45x85x19 $20 qty-1 342183608 1975-76 shim 2 34x45x.500mm $5 qty-5 342074300 1975-76 spring shifter fork rail $5 qty-3 346103603 1975 spacer drive pinion 10.250mm $5 qty-1 346103601 1975 spacer drive pinion 9.900mm $5 qty-1 346103605 1975-76 spacer drive pinion 10.925mm qty-1 interior 693069271 1976 front right 4dr door card $100 qty-1 693060970 ????? door card black $100 qty-1 693115800 1975 2dr rear LH mat black $25 qty-1 664173840 1977-79 brown vinyl/suede front seat back $100 qty-1 664181280 1972-73 rear seat back black $100 qty-1 664171611 1974 front right seat cover -cream $100 qty-1 664171290 1972-73 front seat back rest cover -black $100 qty-1 664171511 1974 front right seat cover -black/cream $100 qty-1 693114370 1973 front RH mat $25 qty-1 693025941 1974 2dr 4dr headliner -beige $100 qty-1 693025940 1973 2dr 4dr headliner -beige $100 qty-1 693073061 1976 4dr front right door card -blue $100 qty-1 SOA-110001 brown twin front rubber floor mats $25 qty-15 chrome 684153081 1972-73 LH rim chrome $50 qty-3 steering 380634400 1974 coupe pinion crown gear set $50 qty-2 this isjust a start to the madness will have more odd and ends but ALOT more sheet metal (doors,hoods,wagon,) bumpers ,chrome moldimgs will take time to get the rest sorted and inventoried thanks
