planemusic
  • Location
    Chicago, IL
  • Referral
    Searched for idle problems about my car.
  • Biography
    I'm an electronics tech (vintage and high end stereo), a synthesizer collector, a bicycle enthusiast.
  • Vehicles
    2005 Subaru Forester
planemusic's Achievements
Newbie
Newbie (1/11)
0
  1. I replaced the plugs and wires with nice NGK stuff. Same problem. There's no CEL on either. Could it be the idle air control valve?
  2. Thanks for the advice, guys. Sorry for the delay. I ended up replacing both the coolant temp sensor and the PCV valve. I checked and cleaned out the valve channel as some folks say it can also get clogged. After replacing the coolant temp sensor the car initially idled better but about ten minutes into a test drive the car started stalling at lights again. That was when I replaced the PCV valve - now the car idles better but not perfect. Though it doesn't stall at lights, it does seem to idle low and a little rougher than I think it should. How much truth do you folks think is in letting the car's ECM relearn how idle?
  3. Thanks for the tip. I did a little research on faulty ECTs with Subarus and it sounds likes it could be the culprit. I ordered a new one and it should be here tomorrow. I quickly tried to find it on my Subaru but came up short. Do you happen to know its location on a 2005 Forester?
  4. I have a 2005 Forester XS with 160K miles on it. This past summer I got stranded up in Maine with a bad spark plug. The spark plugs, wire, and coil were replaced. Following that, the car still didn't idle correctly. I disconnected the battery, waited about 30 minutes, re-connected the battery, turned the ignition to the on position for about 10 seconds, started the car and didn't touch anything and let the ECM relearn how to idle (as is a popular subject on these forums). The car seemed to run fine after that though I thought it idled a little rougher than before the fix. I drove the car though our rough Chicago winter with no problems. The first day that it got warm out the car developed a very rough idle - to the point of stalling at red lights. Now, if its cooler out it will start up normally but once the engine warms up it idles rough and usually stalls out. If its warmer out, as it was yesterday, the car is rough to start (you have to work the gas pedal) and idles really rough and then stalls out. It idles so low that the engine shakes the car uncontrollably. I cleaned the MAF, the throttle body, and the idle air control valve. That seemed to work for a day but it soon went back to idling really rough. What else should I check? Should I just replace the IAC?
