Legback0203
Location
Grant Park, IL
Referral
Google. lots of Subaru stuff
Biography
Bought a legacy two years ago have done some maintenance and now have an outback as well
Vehicles
03 Legacy SE 02 Outback limited
Legback0203's Achievements
Advanced Member (3/11)
0
If its the same as when I put an 00 into an 02 than there will be a different vacuum hose set up from the crank case. The old is slip fit on a fat hose and goes to the intake and I believe the air box. The new only goes to the intake and is threaded into a fitting on the block. If you have an npt tap you should be able to tap the inside of the slip fitting. Worked fine for me. It may not be ideal but I think it's worth it to keep original intake manifold and wiring harness. Mine also had a different style coolant temp sensor so swap coolant crossover pipe as well.
I personally feel like hight of the light is a major factor. My 96 suzuki x90 had really good headlights. I also feel like the "pretty" design alot of manufacturers go for is probably difficult for an engineer to get all that light going the right direction. The headlights on the x90 are pretty round so it seems like it would be easier to make them work.
Have you done this before? I can't seem to get mine to honk. Any more specifics from someone who has successfully done it,such as speed of on off with the ignition or do I need to have the doors all unlocked before I get in or just unlock them after i het in. Ive tried about 8 or 9 times and the instructions are pretty straightforward so I must be doing something to upset the process.
As it turned out it wasn't timing belt at all. The person I got it from got the car in a package deal and didn't know anything. He had been told it broke but had a mechanic supposedly put a new belt on with fingers crossed. As it turns out the belt was probably the same from the last change but the water pump looked fairly new. Some of the timing cover was melted so this car had been seriously over heated. The head gaskets were toast and thus no compression emmulating the supposed bent valves. I'll have the car running some time next week.
