catbus
  • Location
    Knoxville TN
  • Biography
    My first car is an 82 Subaru GL wagon in aztec gold.
  • Vehicles
    1982 Subaru GL
Recent Profile Visitors
376 profile views
catbus's Achievements
Member
Member (2/11)
8
  1. Excuse my weird expression but I took my 82 wagon to cars and coffee this sunday!
  2. This may not be the one you're thinking of, but there are lots of 1st and 2nd hen brochures here: http://a15ff11300g.sakura.ne.jp/catalogue/oversea/oversea.html
  3. The radiator fan on my 82 4WD wagon doesn't work when the headlights are on. It works when the parking lights are on though. the thermoswitch on the radiator seems to be good as the fan works normally and cools the engine fine with the lights off. is this an alternator issue or something? or a bad ground? I'm planning to replace all the grounding straps anyway so I'll see if that helps.
  4. There should be a little drain plug at the bottom of the tank that'll drain it out pretty well. If the gas looks rusty/really dirty, go ahead and remove the tank and clean it out.
  5. Just pulled off the C-pillar trim of my wagon and there are in fact anchor points on each side. I was just asking because I came across a set of front 3 point seatbelts and I figure it couldn't hurt to mount them in the back if possible.
  6. Are there any 3 point seat belt mounts for the rear seats in a 2nd gen wagon? If so, can I mount a couple front seat belts in the rear from, say a 2nd gen coupe? Thanks!
  7. I took my gas tank out for cleaning. Since I've done the Weber conversion, can I just plug some of the ports on the tank that go to the canister? Besides a vent or two it doesn't seem like any of them would serve a purpose anymore. Thanks!
  8. I have an 82 4WD wagon and I'm desperately looking for a spare set of wheels. I don't have access to anything but 3rd gens, so will they fit? Thanks!
