mojoinacoma
Location
CA
Biography
I need many info for my Subaru DL
Vehicles
1976 Subaru DL1600
mojoinacoma's Achievements
Member (2/11)
3
Weber carb installation problem
mojoinacoma replied to mojoinacoma's topic in Historic Subaru Forum: 50's thru 70's
But the question still remains. I'm not sure what to do with the lines that was originally connected to the diaphragms. And I still don't know which ones to cap and which one to connect to the carburetor among the three lines from the front of manifold... pleas help! -
Yes I think it is cold air intake hose. I changed the original hose because it was getting ripped apart. Thanks to monkbonk and spicypeanut for help. Now I know what to do with the hoses that were originally connected to the air cleaner. I'm gonna connect the two vent hoses and connect to filter on weber. I'm just gonna hook another individual small pod filter to the air suction hose. -
Finall two questions!! I not sure waht to do with the anti dieseling thing. It seems like there's no part for it on weber carburetor. And what do I do with the cable that was originally connected to thermosatat cover on old hitach carb? Help!!!! Thank you everyone! -
I have these three lines comming from the frot if manifold and not sure which one goes to carburetor and which one should be vacuum capped. -
Also I have another line next to fuel line which was also connected to air cleaner and i don't know what to do with.. The line comes all the way from the back. -
Third question. It's similar to the second question. Where should I hook up the air suction hose? It was also connected to old air cleaner but like I mentioned there's only one pipe on weber air filter... -
Second question. My manual says they are crankcase vantilation hoses and these were also hooked on to the old air cleaner. But weber kit came with only one pipe that is comming from the air filter. -
Here comes the questions. I put the weber carb on my subaru but not really sure what to do with all the lines because I'm really new to these DIY car fix. First of all, what do i do with the air intake hose? It was connected to air cleaner before but since i ditched the big blue air cleaner I'm not sure where to connect to air intake hose. -
Thanks everyone. The problem is solved! But now I got more questions to ask. Let me introduce my car first though. It's 76 subaru dl 1600 -
Hello everyone! I would like some help from the members here. I was in progress of swaping carburetor and was about to put the adapter plate for the weber carburetor. But four original bolts mounted on manifold would't just come out... Is there any easy ways to get them out? Any recommendations?? Thanks!
