RedneckTech
  • Location
    Ione, CA
  • Referral
    google search
  • Biography
    do it yourselfer who likes to work on cars, trucks, tractors etc
  • Vehicles
    1994 Subaru Legacy L
RedneckTech's Achievements
Newbie
Newbie (1/11)
0
  1. Kudos to you Fairtax4me, had my son look underneath the dash - and sure enough both sets of the connectors you mentioned were plugged in. After disconnecting them, the clicking relays etc went away. Now we'll move on to troubleshoot the no-start...
  2. Greetings all - My son's 9 Legacy died on the road, and initially thought it just was a jumped timing belt. Did the whole rigamorale of installing a new belt pulleys etc..however... After reassmbling everything, found that when the ignition\power was turned on we got these symptoms : check engine light on, no flashing purge control solenoid clicking a\c sub fan relay clicking blower fan relay clicking fuel pump cycling on\off rapidly radiator fan cycling on\off The alternator, starter & battery have all been tested and came back good. Checked and double checked the grounds & battery connections. Replaced the main relay, swapped out the ECU with a known good one, and inspected the fuse box. Replaced the voltage ballast. Nada. Any suggestions? I'm at a complete loss here.....
