wotdsm
wotdsm last won the day on April 27 2016
wotdsm had the most liked content!
  • Location
    Detroit, MI
  • Vehicles
    99 Forester S
Recent Profile Visitors
507 profile views
wotdsm's Achievements
Advanced Member
Advanced Member (3/11)
4
  1. Thanks for the input! I'll look into those adapters. I was under the impression that P1 EJ22E heads mated to P2 EJ251 bumps the compression ratio to about 11.5:1 increasing horsepower to around 165hp...
  2. The only speed bump I forsee is the fact that my current setup is MAP as opposed to MAF. But it seems that EJ18 throttle bodies have a MAP sensor on them so we may be okay there. **EDIT** Scratch that, I guess I'm not seeing a MAP sensor on EJ18 throttle bodies. I could always tee a map sensor into an existing vacuum line if I end up going this route.
  3. I really want to squeeze more power out of my 99 Forester and I want to do it cheap (go figure)... I was thinking of bolting a set of Phase 1 EJ22 heads on to my Phase 2 EJ251 I know P1 EJ22 heads will bolt up to my P2 EJ25 block. But then I'd have to get the P1 intake mani/sensors/accessories to play nice with the P2 ECU. If I splice the pigtails that differ between P1 sensors and the P2 wire harness, use my P2 cam and crank pulleys, and if I source an EJ18 throttle body (has an IACV) it should theoretically work, right? Has anyone ever put a P1 setup where a P2 engine once was? Looking for input on this setup. Thanks
  4. I thought that's for daytime running lights. If you trace it to the end does it connect to a small silver box that says "HOT" on it? That's the DRL diode. I could be wrong but I thought that's what was at that location PS- I have a clock spring I'd let you have for a few dollarbucks.
  5. It could be any number of things unfortunately... Pull codes. There could be one stored in the module that will point you in the right direction.
  6. I ran into this when I replaced my leaky oil pan with a Spectra pan. The o-rings they included with the pan leaked! I used a couple viton o-rings from a Harbor Freight set that includes several variations of sizes that sealed up my pan perfectly.
  7. I second the gates recommendation. Haven't had a gates kit fail on me yet on 15 or so engines I've worked on.
  8. Our coolant temp sensors can cause all sorts of weird issues when they fail... I agree with testing that. PS- if it does test bad, please for the love of God don't buy an aftermarket one. My friend has an 02 OBL with the EZ30 and he replaced his with THREE aftermarket ones that were all junk upon install. The auto parts store actually gave him a hard time about exchanging them... And actually by the third one they told him just to get a used one or new OEM one.
  9. I would change it just for peace of mind. You're right, it's a 14 year old car... Imagine picking up a 14 year old rubberband and stretching it... You know that puppy will be as hard as a rock and will disintegrate in your hands. I know it's not exactly the same. But, it's the same theory. Old rubber deteriorates. Not only that but I assume the car sat for a while to have that low of miles, if a bearing sets in place for too long of time with tension applied to it, it can wear out. I will bet you that the tooth'd idler next to the water pump is starting to get loud.
  10. This sounds stupid but go through every sensor that regulates driveability (crank and cam position, MAF/MAP, coil, coolant temp, O2, etc.) and make sure they're 100% plugged in securely and the locking tab that keeps them plugged in is intact and locked. I was chasing a random misfire (each cylinder would randomly misfire throwing a CEL and the car would buck and hesitate randomly) for a YEAR on my forester. I replaced and tested everything under the sun... Eventually I went to test the OHMs on my crank position sensor (the one sensor I did not test) and the pigtail came unplugged with my pinky. First thought was "no it couldn't be that simple..." Tested the sensor anyways and it was fine, plugged the pigtail in 100% securely and voila, the issue I spent a year losing sleep over was cured... Electronics can be tricky if they don't have a completely reliable signal and the pig tails aren't completely and securely connected and my symptoms mirrored yours, some days the car would run great, other days it misfire and buck under load.
  11. Problem solved. Boy do I feel stupid... The crank position sensor wasn't plugged in all the way. Derp!
  12. Getting super frustrated. Timing was NOT off as I expected it to be - all marks lined up perfectly... I put the belt back on the alt and went for a test drive. Everything was fine during cruising and part throttle. Then I went 75% throttle and it started bucking and hesitating again and eventually got really bad. I was able to get back home and it stalled in my garage and now it won't start. Throwing codes P0340 and P0336, when it cranks the tach wigs out and jumps all over the place. The cam position sensor is known good. I don't get it. I'm at a loss.
