sethicus
Location
canada
Referral
lift kits
Biography
I love subaru and i wanna go into the outback!
Vehicles
98 sti and 96 leggy
sethicus's Achievements
Member (2/11)
0
Hey guys. I did install the subaru springs onto the strut. And i redrilled the bottom bolt too a bigger bolt that fit the new strut perfectly.i cranked on the top bolt nice and tight. When you hit a pothole it feels like the car getting smashed. I have to try and find the accord springs. The parts store cant get them.
Suspension improvements for Subaru Loyale
sethicus replied to Loyale 2.7 Turbo's topic in Suspension
I installed the 4 runner struts I bottom out on almost every single bump now. Kindam of annoying. Now im going to try a different spring to stop my bottoming out. And i even got a lift with the stock springs -
Well on this loyale its got 2 bolts that hold it too the inside of the fender. I installed the rubber bushings like the old ones had. When i jump off the rear bumper you can hear it bang internally. Actually almost any pothole it will bottom out if its more then me in the car. I was maybe going to try some heavier springs now that i already drilled out the old mounts. Kind of crappy. I read that this should fix my problems.
Hey guys today I replaced my old blown struts with 1998 toyota runner front struts into my rear. Now the new struts bottom out on almost every bump. I couldnt get the factory struts here. I read that this is a normal upgrade on thenold loyales. I drive a 1991 loyale. The rear end is also lifted a couple inches witch i read only happens when you use other springs. Im using stock springs i was going to mayne try the accord springs? I cant really do much driving with my car like this. Its a 1991 loyale 4x4. Any info is appreciated
Hey guys i recently pulled my engine out and replaced the head gaskets clutch throwout bearing etc. I noticed there is a squeel on startup and its progressively getting worse. Its a luk clutch and it squeels on cold start up and when accelerating and if i just lightly put my foot on the clutch pedal it will go away. Am i right that im pulling the engine again next week thanks to lul clutches?
Torque wrench jammed on 1 head bolt
sethicus replied to sethicus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It didn't strip. I stopped cause it felt wrong. And it was just 11bolt. Wouldnt i compromise the gasket if i loosend everything? -
Hey guys my torque wrench jammed when i was tightening the 1 bolt on my ea82. On the tightening. I went about half a turn too much. Should i be worried? Im running the felpro headgasket set.
