trainergames
Everything posted by trainergames
Sorry for such late replys but i have been busy with my day job. I have been checking the starter and i also replaced the positive battery terminal connector,because it looked pretty bad. I have noticed that when using the multimeter i would put the positive one on the positive battery terminal and the other on the starter solenoid bolt,and i get a reading of 19 on the second bolt,but the main one with a wire coming from the positive battery terminal,i get a reading of 0. I am wondering if the the battery cable is bad or if it is the starter solenoid that is bad. What do you think? I picked up a 22mm socket,and tried,and while i didn't have much room due to hoses and stuff i got it to move like half an inch.
Well i had posted about the car a couple times before,and the car is a car that got flooded some(but not enough to get into the engine). With a fresh battery the light come on and the windows still roll down,but when i try to start it all that happens is that the lights dim,does not crank and or even click. If it helps i do have a cheap multi meter but not sure where to check.
Top and bottom are both 14mm. I removed the washer fluid res, and i can get my socket on but then i have hoses and steering in the way,i tried a 3in extension and the same things even more in the way. I tried 2 3in extensions and i can a lot better hand grip,but can't get the socket to stay on because the mount for the tranny dipstick is in the way... Any advice?
Ok i am trying to get my starter off so i can take it to autozone and have it checked, so i can start working on getting this car revived... But after getting the top bolt off i am having trouble finding a way to get down to the bottom bolt. Keep in mind i have a basic tool set and currently only have the jack that came with the car...
Thank you for being on my side. I was thinking i might need to replace the ECU,but i am going to remove the starter tomorrow or Friday and try to take it to a parts store to test. If it was bad i will replace it,if not i will replace the ECU. I already checked the oil for signs of water and it was fine so i plan to leave it be just long enough to get the engine to start,once that happens i plan to replace all fluids even the oil,and mabye coolant. I am expecting the wheel bearings,which kinda sucks because we replaced them just weeks before the car flooded... I am hoping to document the rebuild via pics/text and also video when possible,but think i need a name for this project,any one got any idea's?
I am asking because a lot of family and friends are telling me to not,and that it's a lost cause,but i have my own reasons for wanting to. I thought that asking My reasons are one i think it is fixable,also i could of fixed my first years ago,but i didn't and sold it to someone who crushed it...,i have regretted not just fixing it ever since,and am worried i am going to regret not at least trying... Plus i really loved this car... I have been asking on here and elsewhere and we think why it won't start is that the starter is bad. Also once i get the engine to run i would then get all the fluids changed,and then start getting rid of the smell and mold... If it helps here is a link to pics of the water line. https://imgur.com/a/FapJc So what do you guys think?
Ok my current Subaru is not currently working and will take some time to fix it,because it got flooded. Well i am going to be car shopping on Wednesday the 14th,and there is a Subaru on the site of the dealership i will be going to,and i will be looking at it among other cars. I just would love to know what to look out for on this Subaru so I know what to look for to make sure i am getting a good car. The car is a 2002 Subaru Legacy GT Wagon(Auto Trans) with 114K Miles,and according to the CarFax it has been in Texas all it's life.
I chekc and my car has everything that came with the car new,other than the Owner's manual... Where would the fusible link be located? If it helps at all when it first happened the battery was dead and would not take a charge,i replaced it,and all the lights and stuff work,but when i go to start the car the only thing that happens is the light dim,but that is it. It was parked when it happened,and the water level got to half way up the speakers in the door. I checked the oil and there was no water in it,and no water got in the air box either... I have the carpet pulled up on the ECU side let it dry in the hot texas sun,and i have been keeping the windows down with it under a carport. Also there is little to no mold on or under the carpet,most of the mold it has was on the seats and dash from water in the air at the time... Well i really want to at least try,because the my first car was "too far gone"and i to this day still regret selling it and not trying harder to fix it... I pulled the carpet on the ECU side within 2 day of the flood,and it had aired out with the windows down in the Texas sun,and other than some mold on the seats and dash form the humidity,i have seen no signs of rust or mold on or under the carpets.
I am asking because my car got flooded in the flooding in houston Texas and i i think my ECU is dead. I don't think any water got in the engine,i just want to make sure it still works,so i know it is fixable. Because i i know it will start i will do my best to keep it. Money has been kinda tight and i have been having trouble finding a ECU nearby that i can afford. The only one in my town is over an hour away by car(if i had one lol) and they want $120 for it...
I don't think it does,how would i tell? I do have a question for you guys. I have been thinking it is the ECU,but a coworker thinks it might be the starter. So my car got flooded in Texas it got up to the speakers in the door. I already checked for water in the oil and there was none. At first it had no power at all so i bought a charger and tried to charge it,it had no effect. So then i bought a new battery and now it's getting power the radio,lights and windows all work. But when i tried to start the car stuff dimmed like normal,but nothing happened, no clicks or noise of any kind. What do you guys think it is?
Ok i got to get a better look at it today. i checked the oil and air box for signs of water,because that is all i can do till i am able to push it elsewhere,which i have to wait till my apartments put us in a different unit. There was no signs of water in the oil or airbox. Is that a good sign? What are the chances that no water got in the tranny?
I'm in Houston,TX where all the flooding is happened and well my apartment and and car got flooded... The complex is helping us with the getting into another place,but my car is screwed.... Because with all the stuff going on,and some stuff that happened before hand, i had not noticed that my car insurance had lapsed... It was stupid to let it happen but what's done is done... Now i need to look into trying to see if i can fix it. I parked it on the highest ground i could,but it still wasn't enough... The water got half way up the speakers on the door... when i checked the car, i out of habit had hit the door lock button and nothing happened. but i had not disconnected the battery... How screwed is my car? Is there any chance i can fix it?? Because i also really loved this car...
How long do you think it would take to burn off all the excess oil? One problem is i live in apartments so i really don't think they would be okay with my doing an engine swap in the parking lot lol. I took the current loan on my car for 2 reasons,one is i needed a car quickly,because my last car(civic) had it's head gasket and water pump go out at the same time,and was told the engine was likely shot, i only had $750 and there was no driveable cars on craigslist at the time for under $750... The other reason was i was hoping to use it to build my credit, because the only reason my credit is as bad as it is,is because of ER visits that i can't afford to pay... How long do you think it will take to burn off the excess oil? What could the bigger issue be?
Ok I have my 2005 Subaru Impreza 2.5RS(Red in color) it has mostly been a great car,but it is having some problems due to a small stupid mistake i made... Ok it is at about 161k miles i have had it since 138k,and i have had it for over a year and a half. About 2 months had to pay $600+ to replace both rear wheel bearings and rear brake pads. The center diff failed 6 months after i bought it,but i have a fuse in the fuse box that puts it into FWD mode,so i can drive it just fine till i replace the diff. That was just the past problems...now on to the current,i made very stupid mistake,one morning i went to the store and my car went into limp mode...it had happened once before when it had gotten low on oil while waiting for a paycheck to do an oil change. So i stopped at a gas station and put in 2 quarts of oil to last until payday to do an oil change....big mistake,i should have checked the dipstick,it was stupid,i was tired and didn't think. So i way overfilled it it was running fine at first to the store(less than 2 miles from my house),then on the drive back it started smoking white out the exhaust. I have parked it and have not driven it since unless it was for trying to fix it. I did notice oil on the valve cover and down the the spark tube. . I have already changed the oil and when i am off next i plan to clean the spark plugs and wires. There are no signs of a head gasket failure,no overheating,and my coolant looks the same as the day i bought it. If cleaning does not work i will be looking into replacing the valve cover gasket. But i am worried that may not fix it because that tends to be my luck... I am starting to consider trying to sell it or trade it in on another subaru...but one small problem i still owe $2000+ on the car... I am looking at a local subaru dealership it has 2 i might be interested in,but they are like $7k and i don't know if my finance company would let me roll it over to another car,and even if the did i don't know if i could afford the payments on over $9000...(MABYE if the let me have a longer loan time instead of my current 36 months) because my interest rate is not good,i know it is over 20% do to my poor credit score of 585..... What do you guys think i should do?
When the AC system is out of refrigerant does the AC compressor still come on? I am asking because my AC quit working a few months ago,and i first i thought it was just ran out of refrigerant,but i noticed that the compressor no longer turns on when i turn the AC on. Is that normal? Or does it mean my compressor is bad since i don't hear it any more? I am asking because i don't want to spend the money to try to refill it if it was not going to work.
I am asking because i was looking at craigslist out of boredom,and i can across a super cheap outback that says it needs a front diff. Is that the same as the center diff? because i know my 05 impreza has a bad center and i have a fuse in the FWD spot on the engine bay fuse box to keep it from getting worse while i wait till i can find a replacement part. Also if it is bad enough could it make the car undriveable? Even if i put in a fuse like on my impreza? My hope is that if that is the case i could pick it up cheap and pop in a fuse and drive it home,and them fix it when i fix my impreza. They are only asking $450 and it has been on their for 2 weeks. It seems to be in good shape otherwise for it's age,but it does have a lot of miles at 266k miles. Is it even worth it if i can get it at that price or a little cheaper? if it helps here is a link to the ad. http://houston.craigslist.org/cto/5966341145.html
I don't have any access to jack stands right now, and all i currently have is the stock bottle jack,but i went out to my car and put my hand on top of the tire and tried to rock it back and forth. The front wheels were rock solid,but both of the back wheels had noticable play... I also got under the back and grabbed the bumper and shaked the car side to side and saw no play in any of the suspension parts. So i am guessing both wheel bearing's are bad...Right? Also what do you think replacing both wheel bearing's and the center diff is going to cost to replace? because i need to know how much to save up. Also how long do you think i could drive it in this shape? Because i am broke right now.
Earlier last month i made a post trying to find out what a noise was you can read it here. http://www.ultimatesubaru.org/forum/topic/161259-what-are-the-signs-of-a-bad-center-diff/?do=findComment&comment=1342541 Well i finally was able to put in a fuse in the FWD slot,and it fixed the Torque Bind for now,but there are other noises i have had for a while,i would like to find out all my problems so i can fix it all at once. Ok what the noise is, while i am driving straight there is a noise like wind noise but loader from the rear of the car and it,when i turn right i hear what sounds like a tire rubbing(i checked there is not rubbing),and when turning left it sounds like lightly grinding brakes. What could it be? My car is a 2005 Subaru Impreza 2.5RS w/auto transmission.
