No Use
Everything posted by No Use
  1. So i got i checked for codes last night, my friend had a reader thing. No codes. I think with all the battery connecting and disconnecting, when trying to start the car after swap, i might have burned my instrument cluster somehow. I'll find another one, and see if it works. I post what happens, when i change it.
  2. I should check for codes, but don't know where could i do it Gonna see maybe some local shop does it for reasonable price.
  3. Yeah, i checked the fuses - all seems fine. I didn't check the relays yet, i didn't think they would go out , but i'll check them along with grounds. Everything else works, you see. Temp and fuel gauges are fine.
  4. Yeah, i already swapped that one. The thing i forgot to mention, the tach worked for a little, when i started car the first time after swap. But i had to change the cam sprocket and all that, because the car was running like crap (cam and crank pulley differences between the two engines ). So then, when the car was really running, the tach, speedo or odo. didn't work.
  5. Hi! So as the title says, my speedometer, odometer and tach are not working after an engine swap. I have a 99 impreza L, which had 2.2 in it. Few weeks ago i swapped in an ej25 from a 99 RS, and changed the transmission as well (it's the same 3:9 transmission, mine was getting old). Everything seemes to be working nice, except the tach and speedometer. I have everything hooked up, speed sensor on tranny, all the sensons on engine. Any help or input would be greatly appreciated, using speedometer app on the phone is not as convenient
