George1943
Location
Aledo, Texas
Referral
It was referenced on 'The great Subaru Brat' group
Biography
I'm 72 years old. It's been a few years since I've owned a Brat but I've always liked them. I just recently bought a 1981 Brat GL. It needs quite a bit of work but they are getting harder and harder to find, so I bought it.
Vehicles
1981 Subaru Brat GL
Recent Profile Visitors
990 profile views
George1943's Achievements
Advanced Member (3/11)
7
1986 Justy 4WD -- Engine ID Help?
George1943 replied to Rooster47's topic in Old Gen.: 80's GL/DL/XT/Loyales...
From what I can see, it looks like either an EA71 or EA81 4 cylinder. -
The splines in one of my front hubs was stripped out when that happened to me a few years ago.
1983 Subaru GL 4wd - Clutch replacement issues
George1943 replied to Calibud916's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I agree with silverhelme. I'm thinking the grinding noise you heard with the old clutch was the axle slipping in one of the front hubs. Maybe you didn't need a new clutch after all. Try putting it in gear ( two wheel drive ) and with the clutch pedal out, have someone look at the front axles to see if one of them is just spinning in the hub. If it's not moving anyway, you could just get out and check for yourself if you don't have someone to check for you. -
EA71 Piston Orientation
George1943 replied to Otterby's topic in Historic Subaru Forum: 50's thru 70's
77 1.6 valve adjustment
George1943 replied to Thegreasemonkey's topic in Historic Subaru Forum: 50's thru 70's
With the engine cold- 1 reply
- 1
I switched to a Weber and haven't regretted it for a second. Lots of other people have done that too. The only vacuum hoses that I use that I can think of are 1 to the AC control, 1 off of the carb to the distributor vacuum advance , and 1 to the power brake booster. All the others are capped off. I still use the PCV valve but I think some people cap that off too. Hope this helps.
Sway bar end link bushings
George1943 replied to Scoby4wd's topic in Old Gen.: 80's GL/DL/XT/Loyales...
These stabilizer bushings are available at Rock Auto, Oreilly's, and probably other places as well. -
84 brat EA81 a/c low side port?
George1943 replied to StallonePanerai's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The high side is the line that goes to the condenser in front of the radiator.The low is the one that comes from inside the car. The low side hose is bigger than the high side hose. The sight glass eye is on the high side. -
New member Ea-81 hydro lifters
George1943 replied to Darrel504's topic in Old Gen.: 80's GL/DL/XT/Loyales...
In the 'Shop Talk' section, search for 'Adjust hydraulic valve lifter'. There's a write up on how to adjust them.
