rabbidrabbit's Achievements
Member (2/11)
3
Oh and a pic would be nice! Just don't use Photobucket to host it.
You are good on the Forester bits. If you want more lift you need to get the sub frame lift bits from a 98-99 Legacy Outback wagon. There was a pic of all the parts you could get but Photobucket pulled third party hosting so it is pretty much gone. I downloaded it awhile back so excuse the crappy pic. I don't own a scanner. I'm trying to find more info on why it suggest using Forester Transverse Links and if 98-99 Legacy Outback will work okay(I don't see why not). I know they are longer but I am having a hard time getting a set and have the Outback ones.
PLEASE HELP BROKEN HOSE!
rabbidrabbit replied to Nubaru1401's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Take that line to Autozone should be able to get the same size from the bulk roll. I am not 100% sure but that looks like a coolant line that keeps the carb from freezing up in cold weather. -
A/C isn't that hard to work on. Replacing o-rings is pretty simple, just be cautious not to damage the new ones when you put it back together. Most importantly, make sure your system is completely vacuumed of all Freon before doing anything. These lines have quite a bit of pressure and when they pop the blow oil and Freon everywhere. Not good for the eyes or the environment.
The Unofficial "How to Lift your Impreza" Thread
rabbidrabbit replied to Kostamojen's topic in Off Road
Is the transmission cross member the same for auto and manual? -
My 97 Legacy on 99 Outback Wagon springs/struts. Wish I would have done the 1" rear sub frame while I was at it and the 1" trailing arm lift. It is sitting on 225/60/16 Forester rims/tires. The spring/strut was a tight fit and you will have to disconnect the front and rear sway bars, you can reconnect them once it is back on the ground if you want. I left my disconnected.
I do not know much about the Legacy wagon but this is my 97 Legacy L. All I have put on is 99 Outback Wagon strut/spring assemblies and a set of Forester 16" rims with 225/60 tires. I went from 6" of ground clearance to 9" at the front pinch weld. I read a lot but still got really confused on what to do/use. I am not real happy with the tires but for $40 for all four rims and tires I will "suffer" till I can afford better. I think with a 215/75 I might be able to get another .5" lift. I really would like to do a 1" spacer on the rear as it was a tight fit to put the Outback struts in. I also will be doing the rear trailing arm mounts since the rear tire is not centered in the wheel well. Hard to see but it is at 9"
