tanner93loyale
Location
clackamas oregon
Referral
my friend
Vehicles
1993 subaru loyale
Recent Profile Visitors
598 profile views
tanner93loyale's Achievements
Advanced Member (3/11)
2
What have you guys done to get stiffer suspension on your loyales? Im gonna be getting a tow hitch and some 6 bolt hubs so i can get a little bigger tires. Im not lifting it at the moment but i want to tow a little drift boat. Is there any heavier springs/shocks i can get so it doesnt bottom out my car haha? Thanks an advance! -Tanner
more loyale problems.
tanner93loyale replied to tanner93loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Not running poorly, runs great. Just has no power under throttle after it warms up. -
Took my car back to my mechanic and he said that he thought the lack of power could have been an o2 sensor or a clogged cat but i changed both and its still doing it. Ive noticed its fine for the first few pulls in the morning when i first drive it , but as it warms up then it turns gutless... any ideas? I feel like ive tried everything and now its just starting to make me angry. Thanks an advance. -Tanner 93 loyale 4wd 5 speed
Im in the process of fixing my car and was wondering if the two plugs in the back (geen to green and white to white) need to be plugged in. The white was is cel test and the green one is distributor timing test? If not what needs to happen. Have them unplugged or plugged in 93 loyale 4wd 5 speed. -Tanner Thanks
93 loyale cel code 35?
Well either change the solenoid to another factory one or do the whole toyota thing. Idek where i can get another factory one unless i go to pick n pull -
Im having lack of power and cutouts and my cel came on. Read the code and it was 35. Pcv valve or something? What is this and how can i fix it lol. This car has been nothing but a pain
93 loyale lack of power and hesitation
Replaced the cap and rotor and still the same problem. It doensnt show on the tach and missing but its just so sluggish. I know these arent fast cars but it is alot more sluggish then it was before. I almost want to say it it distributor timing like its off but i dont know. I would take it back today but sadley its thanksgiving and they are closed for the next couple of days -
No codes. If timing was off wouldnt it run pretty rough usually? Its like only when floored . I was reading some other posts and somebody was having the same problem. Said he replaced his distributor cap and plug wires and made it perfect again. -
Took it to superior subaru and import they know what they are doing. The did timing belts and cam seals and oil pump seals and other stuff. They have done it hundreds of times. It runs great just boggs and kinda jumps when floored.
