tanner93loyale
Everything posted by tanner93loyale
What have you guys done to get stiffer suspension on your loyales? Im gonna be getting a tow hitch and some 6 bolt hubs so i can get a little bigger tires. Im not lifting it at the moment but i want to tow a little drift boat. Is there any heavier springs/shocks i can get so it doesnt bottom out my car haha? Thanks an advance! -Tanner
more loyale problems.
tanner93loyale replied to tanner93loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Not running poorly, runs great. Just has no power under throttle after it warms up. -
Took my car back to my mechanic and he said that he thought the lack of power could have been an o2 sensor or a clogged cat but i changed both and its still doing it. Ive noticed its fine for the first few pulls in the morning when i first drive it , but as it warms up then it turns gutless... any ideas? I feel like ive tried everything and now its just starting to make me angry. Thanks an advance. -Tanner 93 loyale 4wd 5 speed
Im in the process of fixing my car and was wondering if the two plugs in the back (geen to green and white to white) need to be plugged in. The white was is cel test and the green one is distributor timing test? If not what needs to happen. Have them unplugged or plugged in 93 loyale 4wd 5 speed. -Tanner Thanks
93 loyale cel code 35?
Well either change the solenoid to another factory one or do the whole toyota thing. Idek where i can get another factory one unless i go to pick n pull -
Im having lack of power and cutouts and my cel came on. Read the code and it was 35. Pcv valve or something? What is this and how can i fix it lol. This car has been nothing but a pain
93 loyale lack of power and hesitation
Replaced the cap and rotor and still the same problem. It doensnt show on the tach and missing but its just so sluggish. I know these arent fast cars but it is alot more sluggish then it was before. I almost want to say it it distributor timing like its off but i dont know. I would take it back today but sadley its thanksgiving and they are closed for the next couple of days -
No codes. If timing was off wouldnt it run pretty rough usually? Its like only when floored . I was reading some other posts and somebody was having the same problem. Said he replaced his distributor cap and plug wires and made it perfect again. -
Took it to superior subaru and import they know what they are doing. The did timing belts and cam seals and oil pump seals and other stuff. They have done it hundreds of times. It runs great just boggs and kinda jumps when floored. -
Just dumped 800 dollars into my loyale to get my oil leaks and seals replaced and now it has a lack of power. No rough idle just a lack of power and hesitation when giving it gas. Almost cuts out and when i let off the gas its fine. Mostly does this when floored. Was wondering what the most common problems are? New plugs and wires? Distributor cap? Fuel pump and filter etc. Let me know your thoughts before i drive it off a cliff.
93 loyale stereo wiring help?
Okay well that sucks, I really hate wiring haha is there any short way to explain how to do it. -
Ive just put in a new deck and it says that the left rear negative and the left front negative are the same wires, and so are the right rear and front negatives are both the same wire as well. The left front and back negative is blue and red and the right front and rear negative are blue and black. Does this mean i need to have 4 wires spliced together or is something wrong here lol? Right now only my front speakers are hooked up because i dont want to mess anything up trying to hook up the rear. Any help is appreciated Thanks -Tanner
Noticed a hefty oil puddle on the ground after letting my car sit. I also have the "lifter tick of death" so ive heard i need new oil pump seals. Can bad seals from the oil pump cause that bad of a leak? Also i am going to do oil pan gasket and valve cover gaskets.
