Everything posted by oddcomp
West Coast Subaru Show 7 Thread (real deal)
i will prolly leave this neck of the woods as soon as i get off work just like last one so if anyone is rolling at 7am to head up there lemme know lol
MMmmm new turbo and HKS downpipe
my incoming vnt turbo shall own you all i say !!!!!!!!!!!! hehehehe
spider... not on yet... but it looks fast (new pic)
ahh you suck you did what i wanted to do but ran out of ambition/money to have it polished so i just painted it still look killer tho
something wicked this way comes caution for dialup get a snack
15-17 vw/audi tdi usage the 25 is dodge usage the tdi vw/audi motor is 1.9l
oooh more goody's autometer procomp boost gauge and dun da da dum!!! a garret vnt-15 variable nozzle turbo charger ... after all i gotta keep ahead of the rest of you guys instead of boosting at 2500 3000 rpm i expect results starting at 1000-1500 rpm if not lower a short simple teardown of what it is and such is here http://www.technologie-entwicklung.de/Gasturbines/VNT15-Turbo/body_vnt15-turbo.html
soo.. then would it be okay if people stored their beer at my site then ??? and since they do roll around .. they can be pushed over to the fire area... i can also put a lock on the lid if it helps
those that partook of the beer at the last wcss can attest to how chilly it was
i need to know how much people plan on bringing so i can adjust the amount of large rolling coolers and dry ice accordingly to the beer supply .. also unless people want totally frozen beer the dry ice will need a fairly good layer or regular ice over it i plan to save up enough for like 8 or so bags of regular ice to cover the dry ice but if anyone wants to chip in that would be cool
EA81 (Brat) +EA82 SPFI intake stuff?
the hardest part is prolly just fiddling with the tuneing as that what kinda takes teh longest next to building the box i built mine in about 4 or so days a couple hours at a time in the mornings after work half blitzed and it works
turbo plumbing
i recently learned a little tip from my turbodoge forum for cheap intercooler piping seems alot of those guys run the wire reinforced diesel radiator hose <like 18 wheeler type diesel> much cheaper than silicone stuff
its a putting together thing from when i had it running on msnedis before it ran great but now it will have the spider intake the intercooler and the b.o.v and a 5 speed so i expect it will run even better
ya could squirt it and use any disty you wanted plus ditch the maf and simplify alot of wiring just my .0000000000002 cents what did you spend on the ecu and stuff?
whats you see is a ford thunder chicken intercooler a hks ssqv b.o.v the dis coil pack the coil pack ignition module the saab apc boost controller and of course a spider intake chevy alternator
Optimal Timing for EA82T
nope i just let teh knock indicator tell teh ms the motor is pinging and the ms takes it from there kinda like a double fail safe detonation setup
both before and after and apc does not control timing just boost based on knock
rim rubbing caliper
the nifty junkyard rims i got off a junkyard suby had welds on the inside of the rim that where hitting the brake calipers on the front soo after i put em on a drove happily away from the junkyard i got a nice thunk thunk thunk thunk so on the side of te road i pulled the front tire off and filed down the welds a tiny bit and no more thunk
from hero to zero, its rebirth is coming
hmm odd didn't i think it had a turbo problem at the last wcss?? hmmm
at 10 psi before i went dis i ran about 1.5 -2 deg below's the stock timing setup non intercooled cheap 87 gas and got almost no ping that i could hear
Delta Cam folks
i am working on a oddball theory .. but sincei have a turbo dodge minivan it looks like the cam setup is the same . wich means there may be a possibility of having cam follower's with rollers in them ... next junkyard run i will graba few and check if anyone is interested..
four-link suspension on Soob?
hmm i think when i was last at zaps house i blathered on about some kinda idea like that ... wierd..... i have my own idea's on a floating boxed independant suspension setup
New rear axle for me!!
so you plan on boxing in the rest of that rear frame? i know you have put lots of abuse on that setup and its worked great but maybe i am just a tad on the overbuild it side and get the creepy's when i see the back section of the spring mounts attached to the stock suby body and the front spring mounts on the nifty subframe what with my exceptionally overactive mind i keep seeing visions of bent brat bed dancing in my head
Super Pro Bushing Listing....HERE!
in short woot! what are they poly?
Took the new GL10 for a spin....woohoo
you hear patrick alot huh ....
knock sensor q's
it only retards timing when it hears "ping" like from bad gas or overadvanced timing to much boost if its turbo charged what you could do at least for now is to retard the timing a degree or 2 as a failsafe and run it until you can replace it just a idea
and still...nothing.
actually its a 89 caravan se turbo 2.5 and we are all behind ya.. at least until i get mine back on the road then i might be a little closer lol
