cookie
cookie last won the day on September 1 2006
cookie had the most liked content!
Contact Methods
Website URL
http://
Location
SFO
Ezboard Name
cookie
cookie's Achievements
Elite Master of the Subaru (11/11)
21
Clock issues?
cookie replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Just as a PS I soldered mine on this advice seven years ago and it still works. -
Po 420
cookie replied to cookie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I do suspect the cat is slowly on its way out but so is everything else as she nears 150,000 miles. I have to keep an eye on the oil but as long as it goes though smog I might get a few more years out of the car. -
Po 420
Nice to see you are still a Subie owner Olnick. When I first got the old 99 I was on here all the time to figure out how to fix her up. She's been running without a glitch other than a transmission rebuild and a little service for a few years now. -
Po 420
I think Cougar is right, if the equipment was available it would be best to check. I would think it would have come back on if it was going to, it's a thousand miles now and today I drove it on the freeway to SF twice, that's about 55 miles, slow though SF traffic twice (a lot of lights on 19th ave at rush hour), a trip down to lunch, a couple of miles, and San Bruno, maybe fifteen miles of traffic and lights. I'll be disappointed if it comes back on but I have gotten three years more out of it, and it does look like I may make more yet. I think this total repair has been about $150 which fits my pocketbook better. -
Just a follow up in case it healps anybody else. A few years back I got a PO 420 code on my California 99 Forester. I think it had about 125,000 miles on it then. A couple of places told me I needed new cats at big bucks. I fitted a new front oxegen sensor and the code went away until a few weeks back at about 147,000 miles. I figured it was the front sensor again and ordered the wrong one from a place I could not take it back to. CA and 49 state are different. At that point as soon as I shut off the warning light it would come back in just a few miles. Then I remembered when I bought the front sensor I had also bought the back and not fitted it to see how long it would last. I put that on and the car has been cured for several weeks. The lesson seems to be to change the ox sensors before the big bucks cats (over a grand quotes), and the rear can last a couple of years longer than the front. Oh, and by the way don't order an oxy sensor with out the serial number from anybody who won't take it back.
If it does not touch the gasket surface it should run. The machining seems quite rough if it is not the picture. Was it done on one of those giant beltsander type surfacers? It's not something I'd care to use on anything where combustion volume was critical and you should make sure there is nothing that can make a hot spot, keep all edges smooth. On an around town mom's car that will never see more than 5,000 rpm or so it is unliky to be a problem.
Tow it with dolley and disconnect or on a trailer. As a guy who has blown a head gasket on a mountain and paid through the nose just for 10 gallons of water (wrecker call for the water) a trailer is much better. Climbing mountains is going to put all kinds of changes and strains on an engine you don't get around town. I suspect CCR is going to charge you for a core if you blow it up and it is not rebuildable.
Gary, Are the bearings about the same size? In other engines I've seen an increased rate of bearing failure with more displacement. I can think of one motorcycle program in which the leap from 750 cc to 900 cc ended up being cancelled because of the rate of increased bearing failure. Those dudes went to an entire new power plant.
These Subaru gasket problem is a bit of a bear to diagnose compared to other vehicles I've seen. The good part is that yours is probably not all that bad and some folks would pull the thermostat and limp by for a while. No heat though and in your area that would be shivers. A kid did it over here in CA a while ago and limped by for a couple years of short college trips. After one downtown SF over heat it limped to Lake County by running at night, where it became a parts car. If it were my car from what you say I'd take it to CCR or is that the band? Let them decide how the clutch is, they have to take it our after all. I had 30,000 miles or so on my Forester clutch and we put it back in after the tranny rebulild. It looked good for a long time. This is the same reason I put a lot of money in my Forester this year. Avoiding car payments, higher insurance, registration, etc. when we seem to be going into a recession might be a good idea. I usually get laid off when the republicans are in and get a better job under the Democrats.
