cookie
Everything posted by cookie
Hot Alt!
cookie replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Also try removing the belt (when cool). You can often feel a dragging or rough bearing by spinning. -
In case you don't like it later start by just painting them. If it looks cool powder next year as the paint gets tired. One look I like on Subarus I saw on an older Legacy wagon. The guy had gotten what looked like American car steel wheels, painted to match the car, and put baby moon hubcaps on. I thought it looked kind of macho and probably did not cost a bomb in money, but I bet it took a lot of junkyard time.
an old Subaru that does not leak at all is more rare. Seals seem to last about 100,000 miles and after that seep a bit. Even when they have been replaced 40,000 miles ago like mine I find a small bit of evidence of leakage on the front main. I agree with doing timeing belt, water pump, fint seals and tensioner at the same time. When you need a clutch do the rear seals and the seperator.
temp. control
cookie replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Who is doing the mail while you are goofing off???? Seriously TC, get better soon or you may get to like Opra! -
Yep WA, that's what happens when you stretch an engine. Their entire production line is set up to make these blocks and the cheapest thing to do is bore larger. After you have the crank with as large a stroke you can get this is the only way to get bigger. Due to smog laws the engine have to run much hotter than they used to and much leaner. Closing the deck or O ringing would fix it but be more expensive. They seem to have been going the cheapest way which would be a gasket capable of taking movement. This also explains why engines often fail on a long trip. You get into another whole level of heat soak then and my thoughts are that the liner moves then.
I've never seen that WA, but that would sure do it wouldn't it. I've seen backwards clutch plates, non fitting pilots bearings, misaligned clutch plates plenty. On my commercial trucks I used to sharpen the mainshaft to make the clutch align better because we changed so many clutchs due to SF hills.
WRX in snow.....
cookie replied to newg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The only time I used to get stuck was when I high centered. It just seems the WRX would be more prone to high centering and power is not going to be any use when the wheels are in the air. -
also clean up the pins while you have it out. Lube everything you can lightly, and sometimes a longer bolt can be used to help pull it in. I also use a measurement too, tape or caliper to be sure the gaps are the same top and bottom and side to side. I can't always tell by eye. Even using the clutch alignment tool you can be off. It's best to test fit parts first.
WRX in snow.....
My money would be on the OBW. -
Frankly I think the more you know about cars the more likely you are to change the gaskets if funding permits. Some folks like nipper have purposely run them to see what happens and test thier personal therories (and he was right, the lower end let go before his gaskets). In my cars I really like reliability and I reckon this saves me getting a new car. Maybe it cost me $1500 or so but I have three reliable years behind me (Subaru kicked in bucks later too which I won't count for this purpose). This means reliabilty has now cost me $500 a year. Every year it does not leak reduces the cost furthur.
