Hogan029
  • Location
    calgary Alberta
  • Biography
    hi there just here to learn about some cool vehicles
  • Vehicles
    99 forester
Hogan029's Achievements
Member
Member (2/11)
2
  1. Also my JDM power steering pump has a connector on it, I cant seem to figure out what it should connect to as there is no plug on the US harness
  2. Does anyone have a pin diagram so that I can make sure what is what? just looking for a pin diagram for the connecter to the main harness
  3. Hey thanks for the reply. There are two that I was confused with. I labeled everything so that it was clear for me and future learners.
  4. Hi all, Long story short is that I have a JDM intake which I am trying to use the North American harness on. I was wondering if anyone has a harness diagram to show which plug goes where. I know that I might have to do some modification on to the harness in order to make it work but I am not opposed to doing that. If someone has a pinout diagram, I could trace the lines perhaps? This is my intake. I still have the old harness on it still. Any thought or comments would be appreciated. Cheers, Ryan
  5. hi all. Just wondering if you can name this part. I have a EJ25 USA version which this is on and a JDM EJ25 which doesn't. I am thinking of swapping the U.S. Intake on the JDM as I have a US wiring harness. Thanks all!
  6. Perfect. I will have to go to the wreckers today and see what I can find.
  7. Thanks so much. I have been told that there is a ECU specifically for manual transmissions. I will take a look at that retro-fit forum. Would it require much modification?
  8. hi there. Just picked up a EJ25 DOHC out of a 99 forester. I am now looking for an ECU and complete wiring harness. I had a few questions however. I am going to be using a manual transmission from a Volkswagen with this so do I need the manual ECU? If so, I have been having a heck of a time finding one.. Can you adapt an automatic? Secondly. Is there any difference in the wiring harness from the SOHC and DOHC? Thanks for all of your replies!
