SomeoneWithCarTrouble
Everything posted by SomeoneWithCarTrouble
  1. Okay, so basically, both fans work, I wired the electric one into the car so i could turn it on manually It was sitting about 10 years, but i took out the motor and cleaned it all up, replaced the heads and such I haven't used a thermometer, but i can tell it's getting hot The radiator is the original, and isn't looking great, but i don't see any leaks. I want to buy a new one but it's custom for the xt (like a lot of things) and so is very expensive, but I'll probably get one anyways. Thanks for the help????
  2. Finally fixed up my 86, but i can't drive it much more than 10 without the dash telling me it's getting too got. The radiator is full and and everything. Help appreciated
  3. Have an 85 xt and i don't know if the speedometer cable off an rx without a digital dash will work. Also, how do you get the speedometer cord off with a digital dash? Help appreciated
  4. I've got a 1.8 mpfi, and when i try to start the car it won't go unless you squirt gas directly into the engine. The injectors aren't getting a signal, why would that be? Any help appreciated, thanks
  5. Great, I almost just bought new ones, so this helps me out a lot. I'll let y'all know how it works out and thanks for the imput.
  6. Hi, i have a 1985 subaru xt turbo, and I'm putting the motor back together.I can't get the lifters to pump up, I've put them in oil overnight. Is it really necessary, or will they pump up once i get the car running? Any help would be appreciated.
