TXJayhawk
3
Everything posted by TXJayhawk
1981 Brat GL, rear reservoir but not front of the master cylinder completely drains out. Master cylinder says F (assume Front brakes) under the rear reservoir and R under the front reservoir (assume rear brakes), Mechanic in December said Rear wheel cylinders were leaking and should be replaced (they put on new pads and flushed brake fluid from entire system) Ideas? Maybe flushing caused the master to leak? I have spare NOS Master cylinder plus front caliper rebuild kits and new rear wheel cylinder. What to try first? Also recently welded some rusty bits (maybe a brake line got damaged during the welding but did use welding blankets to cover nearby areas). Any suggestions welcome as right now not driveable.
I have a spare master cylinder (13/16 bore) that was in my parts bin along with rotors for an 80-83 Subaru car (not Brat). Neither fits my 1981 Brat (the 81 needs a 3/4 bore which I just got on eBay-there is one still available) Calipers are non-existent and rotors nearly so. I think I got the last Centric set that popped up on eBay earlier this year. Haven’t tried fitting it yet as my master cylinder rear reservoir keeps draining and need to figure out why. The rotors for the 80-83 car did not fit my 1981 hub when I had new pads put on last December so I had to reinstall the old rotors which are well worn past the safety limit. If you are interested in either or both parts, I would like to get them to someone who can use them.
More rust repair 81 Brat
TXJayhawk replied to TXJayhawk's topic in Historic Subaru Forum: 50's thru 70's
Parts going to be available from this? Still looking for a few items.
used Gen 1 '76-'78 4WD wagon parts in ID
TXJayhawk replied to NLAParts's topic in Historic Subaru Forum: 50's thru 70's
Seats wanted if decent shape photos helpful -
Only one that really is concerning is the drivers side but clean metal is available for welding -not cleaned yet in this photo -
Under fender rust repair 81 BRAT
POR 15 is done. -
Does anyone know what color the blue is? Would model paint or spray paint work best? Mine has absolutely no color left and want to restore it.
Yes it was still there gone now -
Going to use POR 15 (degreaser, metal etching, POR 15) then prime and paint. Any other tips?
Mine has 13mm bolts where it mounts under the fender and a 23 or 24mm bolt on the bottom of the fender
I Where in Texas did you find this thing? I am in Houston and have not seen another Brat in 8 years (out of 7 million people)! i have cylinder head bolts and nuts for an EA71 if you still need them.
combination switch needed for 1st gen BRAT
text me your email for paypal or address for check. Out of town but back Wed Oct 14 -
SuperBrat, I will take a combo switch. Sorry for delay in responding to post. Text 229 563 3099 with info, -
That is my back up plan too.
