presslab
presslab last won the day on October 30 2013
presslab had the most liked content!
About presslab
- Birthday 05/09/1977
Gender
Not Telling
Location
N. California
Occupation
Engineer
Vehicles
GL-10 Wagon
Recent Profile Visitors
presslab's Achievements
Certified Subaru Nut (8/11)
45
rainwater leaking through dash
presslab replied to old McD's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes I've had the same leak from the plastic below the windshield. The other hard to find leak came from cracked sealant inside the rain gutters on the roof. -
I didn't realize this, but I just wanted to give others a heads up. I ordered a half shaft from Rock Auto for my GL10 and when I received it, it was for a Legacy. The part is listed as fitting, but it's obviously wrong. Rock Auto is not paying for the return shipping. Yes, it was their vendor that messed up their interchange list. But as a supplier I feel they have a duty to sell parts that fit regardless of where they get them from. Anyway, I've never needed to return a part to Rock Auto but now I know (and you too) the risk taken when buying from them.
Frankly I haven't paid them any attention since I put them in. There are no funny noises or looseness. Just got new tires (Yokohama AD08 R), still handles awesome. Old tires wore perfect! I'll take a peek and let you guys know if the bushes are wearing at all. A uniball will work fine I imagine, just be noisy and clunky! The reason urethane is used is due to their ability to be firm yet flexible. In all sorts of suspensions the rotational axis is not the same as the bushing axis, not really a problem. On the radius rod I have installed a steel sleeve the same O.D as the bar over the threaded part; this is what allows everything to stay clamped together, so this not a problem either.
Yes the coolant needs to keep flowing to allow the thermostat to regulate the engine temperature. There are a few options. You can install couple tees and do a bypass; you can restrict that bypass somewhat but not that much. You can get a Tom Shiels thermostat housing and use this for the bypass. Or you can use a 4-port heater valve that allows fluid to flow around the heater core when off. On my Vanagon conversion I have a simple bypass, and the heat is still decent.
Yeah I assume these sleeves are really thin sheet metal (like the Speedi-Sleeve), meant to restore the sealing surface when it's worn or damaged. They just press over the original surface with a bit of bearing retainer adhesive. They're thin enough that the seal still works fine (maybe a bit tighter). I can understand the torque converter, because it has a large seal in the front diff housing. But the input shaft I'm not so sure, it just has a static o-ring. The input shaft does have a couple wear surfaces against some bronze bushings, but if this were worn out the bushings would wear faster and be the replacement item.
Is there any side to side movement of the rear diff pinion flange? Does it turn smoothly? Did you check the fluid level? If you remove the driveshaft altogether and drive it (tape a paint can cap over the transmission) does it vibrate? Your tire situation is not ideal, and could damage your center diff / viscous coupling. The front and rear diff do not have a viscous coupling so these can handle a bigger difference in tire size. So swap one new front tire with one old rear tire.
The oil pump in the trans is probably FUBAR. You can swap the oil pump housing from the old trans, but you'll need to do more disassembly. Look at this PDF: https://www.xcceleration.com/trans/4EAT_Phase_II_Automatic_Transmission.pdf You'll also need to use the diff and housing that went with the old pump. Not sure if you're up for going in that deep into the trans...
Ah I didn't think about the plastic pulleys, those must have a magnet in addition to the one in the sensor. I know the metal pulleys don't have a magnet. Anyway hope you figure it out.
The sprocket doesn't have magnets, the sensor has a back bias magnet; this is why you see old sensors will metal filing stuck to them. Might be just a flaky cam sensor. Hook a scope to it and check it out.
I'm going to say that the cam sprocket (trigger wheel) for the cam position sensor is different.
