elRayRay
About elRayRay
- Birthday 09/05/1974
Gender
Not Telling
Location
Hood River, OR
Referral
Google search for subaru off road images
Biography
New Subaru owner here. Years ago, I briefly owned a 1983 GL 5-door 4wd but wasn't in a position to make the necessary repairs to the car to make it more suitable for me. I recently bought a 1987 GL Wagon 4wd and plan to take it up in the woods a lot
Vehicles
1987 GL Wagon 4wd
elRayRay's Achievements
Advanced Member (3/11)
2
This is my understanding, though I would like to hear it from someone else. Maybe ask in the Off road forum?
- 6 replies
- Modifications
- 82 GL Wagon
(and 1 more)
Tagged with:
Having a difficult time extracting the broken bolt. I can't get a good look at it and I'm trying to avoid putting it back together with only 2 bolts in the camshaft cog and rolling the dice... Any advice? Without pulling the front end off, preferably. I need to get it on the road ASAP.
Okay... I have (had) everything back in place for reassembly, and I broke one of the bolts for the passenger-side camshaft cog. Now it looks like I need to get new hardware and extract the broken bolt from the camshaft. Always something...
Battery is dead. Although, I might be able to get a jump from my roommate later.
Finally getting around to this... I can't get the crank pully off and bumping the starter isn't an option. Any ideas? Just keep trying?
Is the kit you're speaking of the one that's going for $1K + on ebay? For that money, I'd rather do an EJ swap.
I've heard that about the water pump. I'm assuming if you're from NJ that your advice about leaving the covers off isn't a bad idea for the PNW. What is this "TOD" of which you speak? Tick Of Death? I'm new to Subaru, and I'm definitely not mechanically, or technically inept. That being said, I need to to be able to do the work on nothing more than jackstands, outside. Is it doable?
Turns out that I broke the timing belt. The mechanic quoted me ~$650 to repair it. He also mentioned that the oil pump may need replaced, too. I'm probably going to just bring it home and either replace the belt myself or look into an EJ swap. What do you think?
https://goo.gl/photos/5jSKR5rwdLQJkgtP8 Here's what the air filter canister looked like. Smells like gasoline and oil mixed. Engine cranks fine, it feels like it "wants" to start.
Driving up to Wahtum Lake this afternoon and the car died. No prior indication of anything wrong. The car was running absolutely fine. I was just cruising along the paved forest service road. I crested a small hill, and saw a small branch across the road. I downshifted, 4th to 3rd (did not overrev), saw that the branch had already been run over and was broken. I pressed the gas pedal to proceed and no throttle. I downshifted to 2nd, tried it again and realized that the engine had stopped. I tried restarting while rolling. Plenty of cranking, no start. Rolled to a stop, tried again, same. Again, no indication of any problem, car was running as normal (not great, but good), and I didn't overrev. I opened the hood to a faint smell of oil. Faint like a dirty engine smells when it's hot. I opened the air filter to an emulification of what looks like oil and gasoline coming from one of the tubes in the air filter canister. Did I blow the head gasket?
Are the front corners in good shape? I would at least like to get a PS headlight. If the corners hold the bulbs properly (mine don't), I'd be interested in those, too. Also, if you have some random dash parts (HVAC controls, radio bezel, fog light switch, working dash clock, etc.) could you take a couple pictures of the instrument panel (and surround) and the lower console?
Gotcha. Thanks again. I'm planning on rewiring the headlights to have the outer pair hi/lo and the inner pair hi-beam only. So if my car isn't red and the front end isn't wrecked, you don't have the parts? ;-)
Thanks for the responses. When you say "light fixture," do you mean the headlight buckets, or is there more? I don't have a DL handy for comparison and still haven't gotten a repair manual. Also, can I use any EA81 or EA82 with the correct setup as a donor?
Hi there. I'm interested in swapping my 87 GL wagon from composite headlights to the 4 rectangle headlight setup. Do I need to swap radiator core support or can I just get the grill, buckets, and lights and bolt them on?
I just got it back from the shop. New plugs and wires, filters, oil, gear lube (apparently, there was NONE in it), and v-belts. Back in the day with Volkswagens, we had this incredible resource called a Bentley manual. Does anything comparable exist for Subaru? The Haynes and Chilton manuals never really had the content of the Bentley. I'm excited to get into this car, and I need to get some stuff fixed in a hurry. It has no exhaust behind the (presumably clogged) cat, the passenger CV has no boot to speak of, and the passenger headlight could be the home of tadpoles. I'm heading to the junkyard soonish.
