Srubendall
Everything posted by Srubendall
Won't restart when warm
Srubendall replied to Srubendall's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Replaced distributor last month, replaced coolant temp sensor. Still no restart when hot -
91 loyale wagon runs and starts first time. After driving for 10 minutes turn off won't restart. Turns over, have spark, have fuel. Checked all plugs and fuses. Let it sit for a couple of hours and no problem restarts and drives fine.
Cleaned crankshaft sensor cd and subie runs great. No bogging in first gear. Checked fuel pressure 22 at idle recommend 20-25. Except it does fall to 10 when u turn off the subie. Checked grounds.looked at evap and gas cap. Does not help on restart with flooring gas pedal but restarts easily after 5 minutes. Looked at fuel injector and it looks like it is spraying but can't tell if it is leaking. Considering running and driving subie because I think it sat for a while. Previous owner did lots of work new seals gaskets etc. still working on it. Thanks for the help
Cleaned distributer/ and disc. Starts and runs great. No stalls Still won't restart when warm. Drive 10 minutes. Turn it off. Still won't restart. Wait 5 min and cools down. Restarts. Checked connections. All are tight. Car runs and idles great. Just won't restart. Fuel pump is new and pressure is wnl. Could it fuel pressure reg. Or is more electrical Thanks for the help
92 Loyale 1.8 5 speed Subie runs and starts idles great. You put it into 1st gear and give it gas and she bogs down like she's starved. Warms up and drives and then won't restart if warm. Subie will turn over, catch and then die. Wait 10 minuts and she starts up. Replaced plugs wires crankshaft sensor cap rotor fuel pump temp sensor ignition coil. been advised it was a clogged catalytic, but checked out. Need help fixing my wagon.
92 loyale with 1.8 and 5 speed Subie runs and drives. If you floor it in first gear it bogs down but idles just fines. After it warms up it drives ok but won't restart when warm. Will turn over start and die. Wait 10 minutes and it restarts. Replaced fuel pump fuel filter temp sensor plugs wires cap rotor camshaft sensor Been working on for 2 weeks and can't figure it out
