habib99
Location
Wales UK
habib99's Achievements
USMB is life! (4/11)
10
EA82T Fuel Pump Loud Bad Noise and running like crap
habib99 replied to habib99's topic in Old Gen.: 80's GL/DL/XT/Loyales...
thanks, obvious now that you've said it - T off, I'll have to take it to a garage anyhow, just can't stand not knowing myself what/how to do it. Thanks again - pressure at the rail - place to start. -
after the regulator or just the raw pump pressure? can you advise the normal range? -
thanks, yes, I think I have it in a decent position - like the stock position, wide bore pipe and short from tank to pump, it's the awful noise that's coming from it that is worrying me. -
Hi everyone. Since swapping my fuel tank for a new one (and relocating it) the fuel pump has developed (getting worse and worse) a loud vibrating grinding type noise and the car is really hard to start and runs like crap. Trying to find someone who can check the fuel pressure tomorrow, I'm away from home and have no tools! Any ideas about a systematic approach to sorting this please?
EA82T Which way does the coolant flow?
yes of course - wouldn't make sense if it didn't pump out through the thermostat - thank you. -
Hi, I'm boosting the coolant flow with and electric pump on an EA82T engine and need to be sure that I set it up in the correct direction! Can anyone tell me which way the coolant flows, which of the two pipes to the rad are in/out so to speak? The engine isn't actually running right now so I cant just test it myself. Thanks
Thanks for that. Those replacement injectors sounds great and a decent price too.
Hi, Searched and found that XT injector flow rates are 185cc, but just wondering what the L series EA82T injector flow rates are? About to take my megasquirted EA82T in a VW based replica car to a rolling road for tuning and it would help to know the injector flow rate - thanks a million if anyone can tell me.
thanks both, yep deffo low for MS purposes (under 4ohms). Thanks, I didnt know it was just a matter of measuring with a multimeter! not using the original harness so the resistors are gone, could get some to replace but the MS unit should be able to manage the injectors straight off. thanks again.
btw I found the one thread that is a bit confusing, but it seems that the stock inj are 2-3ohms which for the sake of MS is 'low' impedance. can someone confirm?
HI can anyone tell me whether the EA82T injectors are high or low impedence (for the sake of a Megasquirt installation).
MSnS Extra advice re: wasted spark system
I've drawn out the piston positions, their movements and stroke function at the beggining of each stroke and it has cleared it all up in my mind. and it matches up with mikeshoup's post. So now I think it is clearer, the spark is just BTDC so firing 1 and 2 together will spark 1 on power stroke and 2 just BEFORE it starts intaking for the intake stroke, so as daeron said, it should be ok, my worry is that the intake fuel might get lit by the wasted spark but otherwise I think 1,2 and 3,4 wasted spark is the way. Confirmed by the EJ's working this way, I think that's decided unless anyone has any doubts, advice to offer, next weekend I'll be attempting the start up so speak now or forever.... -
just used this to try and get clearer in my mind how the 4 stroke works: http://en.wikipedia.org/wiki/Four-stroke_cycle if anyone has a good flat 4 specific link then please let me know. -
ok so 1-2 and 3-4 is probably best - if that 's how the EJs run (is the firing order on EA the same as EJ ?) THen I've got the issue of spark timing to work out! The MS can be programed to fire at wahtever angle - based on the crank trigger wheel sensor. Does anyone have a link to a good explanation of how the engine rotates and how the intake/exhaust etc all works, I think I remember seeing technical data in the manual that gave firing angle for each cylinder, I guess I should be able to use that but I need more of a firm understanding of waht actually happens as the engine turns - basic stuff but it always seems to confuse me -not hard!! thanks for advice so far. -
I'm installing a megasquirt system with the MSnSExtra code with direct coil driving (from a 36-1 toothed wheel welded to the crank pulley) on my EA82T. I've got in a bit of a muddle over the firing order and the cylinder rotation, basically with the wasted spark system two plugs spark together at a time, obviously one is on combustion whilst the other is while the piston is down near the crank. So which two cylinders do I wire up to fire together? I'm managed to get myself confused and now I cant think straght about it! If anyone has already done the MSnSExtra with wasted spark I'd be SOoooooo grateful if you would share your wiring setup and even send me a copy of you msq file? here's hoping
