Wagonfun last won the day on November 28 2016
Wagonfun had the most liked content!
Gender
Male
Location
Milwaukie, Oregon
Interests
Cars,Camping,fishing,Hunting,Running,Kettlebells,and Music
Occupation
Electrician
Referral
search engine: off road Legacy
Vehicles
1993 Legacy Wagon
Wagonfun's Achievements
Member (2/11)
6
Tried a later model air box to see if there were any gains to be had. Seemed like there were vary modest if any. No change or improvement in gas mileage. http://imageshack.com/a/img924/9091/RgDlTk.jpg http://imageshack.com/a/img924/9441/FB56V7.jpg
Bennie, I haven't used any other LEDs yet. But I have been thinking about switching to red now getting bored with the green. I think the raised roof model here is referred to as the GT here in the States but I've only seen a handful around the flat roof is much more common. I have made a few more improvements since my last post I will get picture and put them up.
Looks like what I went with the same tires, wheel, and strut combination. I've been Happy with mine so far. She not super fast off the line, but I keep up with traffic. :-)
New tires! I got some Yokohama Geolander A/T-S 215/60r16. Painted the wheels black and painted the caliper red for that Pop!
To get pictures to post so they're not a thumbnail I've had to put my pictures in a photobucket account and post them from there. All my pictures were coming up thumbnail before this, I have not figured out an easier way yet.
The old struts make some noises every once in while when you hit a bump or pothole my guess is that they are original. So I decided to get new and give her a little lift with 1997 Outback struts. Struts and springs are assembled maybe next week I'll have time to install. Before I started my 1994 Legacy sat with the top of the wheel well at 26" Found time this week to install the struts that I had prepared earlier in the month. While installing I learned a few things on the way. 1997 Outback highhats are the same as 1994 legacy highhats but only in the front. The rear of the Outback is a one piece unit and the bolt pattern is larger where as the 94 Legacy is a two piece with a small bolt pattern. The shoulder for the Outback strut is much larger to accommodate the one piece highhat spring perch set up. I Found that a 5/8 Grade #8 split washer was about the perfect fit for a shim So my end results turn out with 28" so I gained 2" of lift and a new set of struts! And Clearance enough to drive over and empty bottle sitting upright.
Added a trailer hitch and trailer wire assembly so I can pull a trailer and maybe a small boat.
Got the fog light wiring harness installed and had a few dash lights out I replaced them with green LEDs to match the Stereo.
While searching they wrecking yard for the large pocket I came across these factory Subaru fog lights with complete with wiring harness! I thought they were cool so I brought them home too. :-)
I wanted a cleaner look so browsed Pick-n-Pull till I found the large pocket with the door so I could install a single din stereo with a clean Look.
The old car stereo sucked, it was ugly and an ugly installation.
Picked up a 93 Legacy wagon in August of last year. Its in pretty good shape I've just been driving back and forth to work it's proved to be solid. So I have now decided to sink some money in to it and have some Fun!
